Different answer from teacher's .
  • Thread starter Thread starter dncnqn
The discussion centers on a physics problem involving the calculation of the magnitude of charge on two equal but opposite point charges, given an electric field of 1750 N/C at the midpoint and a distance of 16.0 cm between the charges. The user calculated a charge of 4.98 x 10^-9 C, while the teacher provided an answer of 6.2 x 10^-10 C. The correct approach involves understanding that the electric field is a result of both charges and cannot use one of the charges as a test charge in the equation E=F/q. The user is advised to derive the electric field expression for point charges and consider the superposition principle.
  • Understanding of electric fields and point charges
  • Familiarity with the superposition principle in electrostatics
  • Knowledge of the equation E=F/q and its application
  • Ability to derive the electric field expression for a point charge
  • Derive the electric field expression for a point charge
  • Study the superposition principle in electrostatics
  • Review the application of E=F/q in electric field problems
  • Explore common mistakes in electrostatics calculations
Students studying physics, particularly those focusing on electrostatics, as well as educators looking to clarify concepts related to electric fields and charge calculations.
dncnqn
different answer from teacher's...
Okay, here's what the question says in my book: The electric field midway between two equal but opposite point charges is 1750 N/C, and the distance between the charges is 16.0 cm. What is the magnitude of the charge on each?
I found what the force would be equal to and put it in place of F in E=F/q. When I worked it out I got 4.98 x 10^-9 C but the answer my teacher gave us was 6.2 x 10^-10 C. So am I not getting it or did he give the wrong answer? Any help would be much appreciated, thanks!
Er... what "force" are you calculating? The force exerted on one by the other? How could you know this? All you are given is the electric field at the midway point. There's NO charge here for you to use for the "q" in F=qE. Both of the charges given combine to produce the "E". None of them can be used as a "test charge" anymore for you to use as "q". They are both the SOURCE of the electric field.
Look up (or derive) the expression of the E-field for a point charge. You have two point charges. The electric field at the midway point for your problem is the superposition from each of them. In fact, since the point is on a line between these two, and the E-field from each points in the same direction, the E-field from the individual charges ADDS.
Zz.
It's possible that your teacher may have made a mistake in their calculation or used a different method to find the answer. It's always important to double check your work and make sure all the steps are correct. If you're still unsure, it's always a good idea to ask your teacher for clarification or to go over the problem again in class. Sometimes there can be multiple ways to solve a problem and it's important to understand all the different approaches. Keep up the good work and don't be afraid to ask for help when needed!
  • · Replies 30 ·
10K
  • · Replies 23 ·
