How Do You Solve w=0.5(z+1/z) for Complex w?
The discussion centers on solving the equation w=0.5(z+1/z) for complex values of w, particularly focusing on proving that there are exactly two solutions for w≠±1. The scope includes mathematical reasoning and exploration of complex numbers.
  • Exploratory, Mathematical reasoning, Homework-related
  • One participant expresses confusion about proving the existence of two solutions for the given equation and seeks guidance.
  • Another participant suggests multiplying both sides of the equation by 2z as a potential step in the solution process.
  • A participant proposes that finding the solutions directly is the best approach, referencing the quadratic formula as applicable even for complex coefficients.
  • There is a mention of the quadratic formula and its use in solving for z, with a note that substituting values for w or z could help in determining the other variable.
  • One participant acknowledges their uncertainty about finding the square root of a complex number but suggests writing the solution in radical form.
  • A new participant shares their first post, indicating that they are still learning and unsure about the solution process.
Participants do not reach a consensus on the method to prove the existence of two solutions, and multiple approaches are suggested without agreement on a definitive solution.
There are unresolved aspects regarding the application of the quadratic formula and the handling of complex numbers, as well as the dependence on specific substitutions for w or z.
Macarenses
How does one prove that for w≠+-1 , w a complex number, there are exactly 2 solutions to the equation w=0.5(z+1/z)? I'm at a total loss here. Could someone clue me in on this one?
What if you multiplied each side by 2z?
The best way to prove there are two solutions is to find them! That is what ramsey2879 is suggesting.
I do believe that the quadratic formula will work for equations with complex coefficients even if it is not clear (at least to me) how to find the square root of a complex number. Just write the solution out in the radical form simplified as far as posible.
Do a internet search: complex numbers solve square root
w=0.5(z+1/z)
w=0.5z+0.5/z
wz=0.5z^2+0.5
0.5z^2+0.5-wz=0
If you could substitute a value of either w or z you could work out the other using Quadratic Formula
x = (-b +- sqrt(b^2-4ac))/2a
Other than this, I can't see how you solve it since you have 2 unknowns. Either way you have a squared value for z so z has 2 solutions.
Sorry if I was no help, this is my first post here as I just joined today. :)
  • · Replies 0 ·
  • · Replies 19 ·
