A couple of questions regarding to my calculus work.
  • Context: Undergrad
  • Thread starter Thread starter JJRKnights
    Calculus Couple Work
This discussion focuses on vector fields, specifically the vector field F = <-y, x>/(x^2 + y^2) and its representation as F = < -y/(x^2+y^2), x/(x^2 + y^2)>. It establishes that this representation indicates that 1/(x^2 + y^2) is a scalar. The conversation also addresses how to demonstrate that certain vector fields, such as F = <-y, x>/|r|^p, are not conservative for p = 2 by integrating around a unit circle, resulting in a non-zero integral. Additionally, it explains how to find normal vectors to surfaces like spheres and paraboloids using parameterization and cross products.
  • Understanding of vector fields and their properties
  • Familiarity with the concept of conservative vector fields
  • Knowledge of parameterization of surfaces in three-dimensional space
  • Proficiency in calculus, particularly integration and differentiation
  • Study the properties of conservative vector fields and potential functions
  • Learn about the application of Green's Theorem in determining conservativeness
  • Explore the method of finding normal vectors using the cross product in vector calculus
  • Investigate the implications of surface integrals and flux in vector fields
Students and professionals in mathematics, physics, and engineering who are working with vector fields, particularly those interested in understanding conservativeness and surface integrals.
JJRKnights
1.If you have a vector field F = <-y,x>/(x^2 + y^2)
is that the same thing as saying: F = < -y/(x^2+y^2), x/(x^2 + y^2)>?
That's basically saying that the function 1/(x^2 + y^2) is a scalar.
2.How do you show that vector fields are not conservative for certain values?
Ex: F = <-y,x>/|r|^p show it's not conservative for p = 2.
3. How do you find normal vectors to rounded surfaces given a vector field and the function of the rounded surface? (paraboloids, spheres)
Can anybody say anything on this?
They should be simple questions to people more skilled than I am.
Yes, that is correct.
A vector field, F, is "conservative" on a region if its integral from one point in that region to another is independent of the path. That leads to the fact that the integral around a closed path must be 0. It can be shown that that is the same as saying it has a "potential function", a scalar function, [itex]\phi[/itex] such that [itex]\nabla \phi= F[/itex]. In that case, if F= <f(x,y), g(x,y)>, we must have [itex]\partial \phi/\partial x= f(x, y)[/itex] and [itex]\partial \phi/\partial y= g(x,y)[/itex]. And now the "mixed derivatives", [itex]\partial^2\phi/\partial x\partial y= f_y(x,y)[/itex] and [itex]\partial^2\phi/\partial x\partial y= g_x[/itex], must be equal so we must have [itex]f_y= g_x[/itex]. This last is a necessary condition for a "conservative" vector field but is a "sufficient" condition only if the function is continuous in a "simply connected" region. I mention that because in your next example the function is not continuous at (0, 0) and so not in any region containing that point.
Integrate around the unit circle: [itex]x= cos(\theta)[/itex] and [itex]y= sin(\theta)[/itex] so that [itex]d\vec{r}= (-sin(\theta)\vec{i}+ cos(\theta)\vec{j})d\theta[/itex] and the function is [itex]-y\vec{i}+ x\vec{j}= -sin(\theta)\vec{i}+ cos(\theta)\vec{j}[/itex] and the integral becomes
[tex]\int_0^{2\pi} (-sin(\theta)\vec{i}+ cos(\theta)\vec{j})(-sin(\theta)\vec{i}+ cos(\theta)\vec{j})d\theta= \int_0^{2\pi} (1)d\theta= 2\pi[/tex]
Since that is not 0, the function is not conservative.
A surface is two dimensional and so can be written in terms of two parameters: [itex]\vec{r}= f(u, v)\vec{i}+ g(u,v)\vec{j}+ h(u,v)\vec{k}[/itex]. The two derivative vectors, [itex]\vec{r}_u= f_u\vec{i}+ g_u\vec{j}+ h_u\vec{k}[/itex] and [itex]\vec{r}_v= f_v\vec{i}+ g_v\vec{j}+ h_v\vec{k}[/itex] lie in the tangent plane at each point. their cross product is a normal vector to the surface and, in fact, its length gives the "differential of surface area".
For example, the sphere of radius R can be written using spherical coordinates with [itex]\rho= R[/itex], a constant. Then
[tex]\vec{r}= x\vec{i}+ y\vec{j}+ z\vec{k}= Rcos(\theta)sin(\phi)\vec{i}+ Rsin(\theta)sin(\phi)\vec{j}+ Rcos(\phi)\vec{k}[/tex]
[tex]\vec{r}_\theta= -Rsin(\theta)sin(\phi)\vec{i}+ Rcos(\theta)sin(\phi)\vec{j}[/tex]
and
[tex]\vec{r}_\phi= Rcos(\theta)cos(\phi)\vec{i}+ Rsin(\theta)cos(\phi)\vec{j}- Rsin(\phi)\vec{k}[/tex]
have cross product
[tex]\left|\begin{array}{ccc}\vec{i} & \vec{j} & \vec{k} \\ R cos(\theta)cos(\phi) & Rsin(\theta)cos(\phi) & -Rsin(\phi) \\ -Rsin(\theta)sin(\phi) & Rcos(\theta)sin(\phi) & 0 \end{array}\right|= R^2cos(\theta)sin^2(\phi)\vec{i}+ R^2sin(\theta)sin^2(\phi)\vec{j}+ R^2sin(\phi)cos(\phi)\vec{k}[/tex]
(This is called the "fundamental vector product" for this surface.)
Note that the length of that vector is [itex]R^2sin(\phi)[/itex] and that [itex]R^2sin(\phi)d\theta d\phi[/itex] is the differential of surface area for a sphere.
To determing the flux of a vector function, [itex]F= f(x,y,z)\vec{i}+ g(x,y,z)\vec{j}+ g(x,y,z)\vec{k}[/itex] through that surface, convert x, y, and z to [itex]\theta[/itex] and [itex]\phi[/itex] , take the dot product of F with that "fundamental vector product" and integrate with respect to [itex]\theta[/itex] and [itex]\phi[/itex].
