New Reply
Resistor Heat Dissipation (with imaginary numbers)
Share Thread Thread Tools
Nov29-11, 09:55 PM   #1
Friends:
I am wondering about heat dissipation when you have imaginary numbers.
Lets say a current I = (3 + 4j) Amps is going through an impedance Z = (2 + 3j) Ohms. What is the amount of heat dissipated by the impedance?
I think that you take the magnitude of the current, |I| = 5 Amps, and then find the heat dissipated by only the real part of the impedance, Re(Z) = 2. The heat dissipated would be P = (5^2)*2 = 50 W.
Is this correct?
Note: This is not a homework question. This is something I just wanted to verify.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Nov30-11, 12:05 AM   #2
Recognitions:
Homework Helper Homework Help
The RMS power is:
[tex]P_{RMS}={|I|^2 \over 2} |Z|[/tex]
New Reply
Tags
dissipation, heat, imaginary, impedance, resistance
Thread Tools
Similar Threads for: Resistor Heat Dissipation (with imaginary numbers)
Thread Forum Replies
Help with resistor power dissipation homework Engineering, Comp Sci, & Technology Homework 5
A new set of numbers as a z-Axis to imaginary and real numbers? General Math 9
Resistor: Low Heat Capacity, Low TCR, Constant heat dissipation Electrical Engineering 4
Imaginary numbers and Imaginary Time General Math 5
imaginary numbers General Physics 4
