Stone-Weierstrass theorem problem
  • Thread starter Thread starter cogito²
    Theorem
The discussion centers on the application of the Stone-Weierstrass theorem in constructing an algebra of continuous functions. The user is tasked with demonstrating that their algebra, denoted as A, is closed under addition, which is essential for the theorem's application. The user initially struggles with this concept but realizes that sums are inherently included by definition. The conversation emphasizes the importance of ensuring that the algebra separates points, contains constant functions, and is closed under multiplication and addition.
  • Understanding of the Stone-Weierstrass theorem
  • Knowledge of continuous functions and their properties
  • Familiarity with algebraic structures in functional analysis
  • Basic concepts of compact spaces in topology
  • Explore the proof and applications of the Stone-Weierstrass theorem
  • Study the properties of algebras of continuous functions
  • Investigate examples of algebras constructed from trigonometric and polynomial functions
  • Learn about the closure properties of function spaces in analysis
Mathematicians, students of functional analysis, and anyone interested in the applications of the Stone-Weierstrass theorem in continuous function theory.
cogito²
I'm working on a problem that has to do with the Stone-Weierstrass theorem. This is the problem:
Let [itex]X[/itex] and [itex]Y[/itex] be compact spaces. Then for each continuous real-valued function [itex]f[/itex] on [tex]X \times Y[/tex] and each [tex]\epsilon > 0[/tex] there exist continuous real-valued functions [itex]g_1,\ldots,g_n[/itex] on [itex]X[/itex] and [tex]h_1,\ldots,h_n[/tex] on [itex]Y[/itex] such that for each [tex](x,y) \in X \times Y, |f(x,y) - \sum_{i=1}^n g_i(x)h_i(y)| < \epsilon.[/tex]
The way that I've been trying to do it is to produce an algebra of continuous functions that separates points and contains constant functions. If I define [itex]A[/itex] to be the set of all \sum_{i=1}^n g_ih_i where [itex]g_1,\ldots,g_n[/itex] are continuous on [itex]X[/itex] and [tex]h_1,\ldots,h_n[/tex] are continuous on [itex]Y[/itex], it is easy to show that constant multiples of functions in [itex]A[/itex] are in [itex]A[/itex], [itex]A[/itex] is closed under multiplication, [itex]A[/itex] separates points, and [itex]A[/itex] contains the constant functions. What I am having trouble showing is that [itex]A[/itex] is closed under addition (ie. that [itex]A[/itex] actually is an algebra). Is this true? If it is not then does anybody know of a way to come up with an algebra for this problem so that I could apply Stone-Weierstrass? Any help would be greatly appreciated.
Okay now I feel stupid. Now thinking about it sums are included basically by definition.
The Stone-Weierstrass theorem is a powerful tool in analysis and it is great that you are working on a problem related to it. Your approach of constructing an algebra of continuous functions that separates points and contains constant functions is a good start. However, as you have mentioned, the key to applying the Stone-Weierstrass theorem is to show that your algebra is closed under addition.
To show this, you can use the fact that the product of two continuous functions is also continuous. So, if you have two functions in your algebra A, say f and g, then their product fg is also in A. Then, you can use the fact that the sum of two functions can be written as the difference of two products: (f+g) = (f+g) - (f-g). Since A is closed under multiplication and subtraction, it follows that A is also closed under addition.
If you are still having trouble showing that A is an algebra, you can try to construct a different algebra that satisfies the conditions of the Stone-Weierstrass theorem. For example, you can try to construct an algebra of trigonometric functions or polynomial functions that separates points and contains constant functions. It may also be helpful to look at examples of problems where the Stone-Weierstrass theorem has been applied to gain some insight into how to construct an appropriate algebra.
Overall, it is important to carefully consider the conditions of the Stone-Weierstrass theorem and to make sure that your algebra satisfies all of them. This may require some trial and error, but with persistence, you can definitely find an appropriate algebra for your problem. Good luck!
