| New Reply |
Variation of Pressure with Depth |
Share Thread | Thread Tools |
| Nov30-11, 12:23 PM | #1 |
By what factor is the total pressure greater at a depth of 850 m of sea water than at the surface where the pressure is one atmosphere? (water density = 1000 kg/m3, one atmosphere pressure = 1.01 x 105 Pascals (N/m2), g = 9.8 m/s2 ) 2. Relevant equations P=P(initial)+ρgh 3. The attempt at a solution P=(1.01x10^5)+(1000kg/m^3*9.8m/s^2*850m) |
| Nov30-11, 12:51 PM | #2 |
Your calculation gives you the pressure at the depth of 850m. The question is worded....'by what factor is the total pressure greater at a depth of 850m..... I think this means you are expected to give your answer as a ratio??
| Nov30-11, 01:08 PM | #3 |
ok, well how would I do that? the possible answers to the question are a. 100, b. 83, c. 74, d. 19. That is where I am stuck.
| Nov30-11, 01:19 PM | #4 |
using P = hρg I got the pressure due to the water to be 8.33 x 10^6 Pa
Atmospheric pressure is 1.01 x 10^5 Pa Get the ratio ???? |
| New Reply |
| Thread Tools | |
Similar Threads for: Variation of Pressure with Depth
| pascal's law and variation of pressure with depth | Introductory Physics Homework | 9 | ||
| Variation of g with altitude and depth | Introductory Physics Homework | 4 | ||
| Variation of Pressure with Depth | Introductory Physics Homework | 1 | ||
| Water depth pressure against air pressure | Classical Physics | 1 | ||
