A sum of Cosines (Fouries series)
  • Context: Graduate
  • Thread starter Thread starter phonic
    Series Sum
The discussion focuses on calculating the infinite sum of cosines represented as \(\sum_{n=1}^\infty \cos(nx)\). The key approach involves using the formula \(\cos \alpha = \frac{e^{i\alpha} + e^{-i\alpha}}{2}\) and applying geometric series formulas. An alternative method discussed is to compute \(\sum_{n=1}^{\infty} (\cos nx + i\sin nx)\) and then separate the real and imaginary components to derive both the sum of cosines and sines.
  • Understanding of complex numbers and Euler's formula
  • Familiarity with geometric series
  • Knowledge of Fourier series concepts
  • Basic skills in manipulating infinite series
  • Study the derivation of Fourier series
  • Learn about convergence of infinite series
  • Explore applications of complex analysis in signal processing
  • Investigate the relationship between sine and cosine sums
Mathematicians, physics students, and anyone interested in advanced calculus and series analysis will benefit from this discussion.
phonic
Dear All,
I wonder how to calculate the sum of the following Cosines:
[itex] \sum_{n=1}^\infty \cos(nx)[/itex]
Can anyone give a hint? Thanks a lot!
First, use the following formula:
[tex]\cos \alpha= \frac{e^{i\alpha}+e^{-i\alpha}}{2}.[/tex]
Then apply formulas of geometric series.
A little simpler is to directly compute
[tex]\sum_{n=1}^{\infty} (\cos nx + i\sin nx)[/tex]
and at the end separate the real and imaginary parts. Also gives you the sume of sines.
  • · Replies 139 ·
12K
  • · Replies 33 ·
