What is the stability proof for a PI controller in a formation flying system?
The discussion focuses on proving the stability of a Proportional-Integral (PI) controller used in a formation flying system involving two satellites affected by J2 perturbation and drag. The controller aims to maintain a zero error in the along-track position between the satellites. To establish stability, the user is advised to utilize Ragazzini's method for discrete controller design and analyze the locus plot of the system to determine the poles' locations in the s-plane, which directly influence stability.
  • Understanding of Proportional-Integral (PI) controller design
  • Knowledge of nonlinear dynamics and equations of motion
  • Familiarity with Ragazzini's method for discrete control systems
  • Basic concepts of poles and stability in the s-plane
  • Research Ragazzini's method for discrete controller design
  • Learn how to create and interpret a locus plot for control systems
  • Study the relationship between Ordinary Differential Equations (ODE) and Laplace transforms
  • Explore advanced stability analysis techniques for nonlinear systems
Aerospace engineers, control system designers, and researchers working on satellite formation flying and stability analysis of nonlinear control systems.
fernandoz
I have two satellites flying in formation geverned by the equations of motion including J2 and drag. Now, one of the satellites has more drag than the other so they become appart. I designed a controller (proportional integral) which meassures the along track position between them and gives Thrust values so the error, which is the difference in the along ttrack position between different orbits, will be zero (that means they will still fly in formation)
I have to give a stability proof for the controller, someone can help me? (the equations governing the system are nonlinear, of course).
thanks!
There are various techniques to design a controller. If you want guaranteed performance try searching for Ragazzini's method and of course I'm assuming you are trying to design a discrete controller.
If you insists on using a PI controller to see if it's stable you'll have to get the locus plot of the system (plant + controller) and see where the poles are located in the s-plane.
If you are puzzled as to why the poles' locations determine stability then you'll have to study ODE (as a good starting point) and its connection to Laplace transform.
  • · Replies 21 ·
9K
11K
  • · Replies 25 ·
