Why Do Water Waves Behave Mathematically as They Do?
  • Context: Undergrad
  • Thread starter Thread starter nhmllr
    Water Waves
The discussion revolves around the mathematical behavior of water waves, specifically addressing questions about the relationship between wave height and energy, the sinusoidal nature of waves, and the underlying physics concepts such as potential and kinetic energy. Participants explore theoretical and conceptual aspects of wave mechanics.
  • One participant asks why the energy deposited by a wave when it hits a wall is proportional to the height squared.
  • Another participant suggests that the energy in a wave is proportional to the square of its amplitude, drawing an analogy to simple harmonic motion.
  • Some participants propose that water waves can be expressed mathematically as sums of sine waves, referencing Fourier analysis.
  • There is a discussion about the intuitive understanding of wave amplitude and kinetic energy, with one participant questioning the relationship between height and kinetic energy in the context of projectile motion.
  • Another participant clarifies that potential energy for waves can be expressed as an integral involving mass density and height.
  • Confusion arises regarding the notation used for mass density, with a participant mistakenly interpreting it as period.
Participants express varying degrees of understanding and interpretations of the relationships between wave properties, energy, and mathematical representations. There is no consensus on the explanations provided, and multiple viewpoints remain present throughout the discussion.
Some participants reference mathematical concepts such as Fourier series and integrals without fully resolving the implications or assumptions behind these mathematical tools. The discussion includes unresolved questions about the derivation of certain equations and the definitions of terms used.
This discussion may be useful for individuals interested in wave mechanics, mathematical modeling of physical phenomena, and those seeking clarification on the relationships between energy, amplitude, and wave behavior.
nhmllr
I don't really understand the math of these things, so maybe one of you could help me. :)
Answer any of these questions that you can.
1. Why is the energy deposited by a wave when it hits a wall at a position proportional to the height squared?
2. Are the waves sinusoidal, and if so what's the good mathematical reason for it?
For reference, I know some basic differential and integral calculus.
Thanks a ton
Do you know any wave theory? Do you know what the terms phase velocity, group velocity and dispersion mean?
1) Because the energy in a wave is proportional to the square of its "height" (better call it amplitude).
(There's a full analogy between waves and simple harmonic motion. Take a look at: http://en.wikipedia.org/wiki/Simple_harmonic_motion#Energy_of_simple_harmonic_motion )
2) They need not be sinusoidal, but any (sufficiently well behaved) periodic function can be described as a sum of sines and cosines. The mathematical reason behind this is called Fourier analysis. Take a look at http://en.wikipedia.org/wiki/Fourier_series .
Beyond the links that have already been given, you may try to think of the wave intuitively in the following way:
For a wave of a given frequency to have a larger amplitude, the water has to move faster during each cycle? Kinetic energy goes as velocity squared.
2. Water waves are often expressed mathematically as sums of sine waves (Fourier series). In practice they are generally not observed to be very sinusoidal in appearance (even though very long waves may be close).
Hm... perhaps. But for simple trajectory motion, the maximum height acheived by the projectile is v2/2g (unless I did it wrong), so it would seem there that
h ~ v2, and KE ~ v2, so shouldn't h ~ KE?
(Although I realize that simple projectile motion might not describe water waves.)
I think that usually such waves can be modeled by harmonic motions. Practically between short periods, the pattern is quite close to simple harmonic motion (when the daping is quite small). In harmonic motions energies are proportional to amplitudes.
And sinusoidal patterns are usually the solutions to harmonic patterns. Possibly you could get that analyzing the force experienced by small objects at the surface of the water.
No, it's a good question. As you said, PE ~ h, and PE and KE are conserved during the motion.
The difference between the projectile and the wave is that the projectile is an object with a certain mass m, so PE = mgh. The wave has a potential energy PE = ∫ ρgz dz, where the integral is over all the water "involved" in the wave. The limits of integration are from 0 to the height h of the wave, so PE = ρgh^2.
Quick question- what does ρ represent?
Also, how did you obtain that integral, ∫ ρgz dz?
Thanks
EDIT: Ah, ρ is the period. Although I'm still confused about the integral.
ρ is mass density, e.g., in kg / m^3.
Hence there is an analogy between mgh (potential energy for a particle) and∫ ρgz dz, which is just potential energy (per unit Area) for the surface wave.
  • · Replies 20 ·
