Enzyme Kinetics: Measuring Inhibitory Effects and Determining Km and Vmax Values
  • Thread starter Thread starter Sitix
    Kinetics
This discussion focuses on enzyme kinetics, specifically measuring inhibitory effects and determining Km and Vmax values using a Lineweaver-Burk plot. The practical involves creating a calibration graph with varying concentrations of D-glucose and D-fructose, followed by measuring absorbance with a spectrophotometer at 540 nm. The results include absorbance data for reactions with and without inhibitors, specifically fructose and urea, which are analyzed to determine initial reaction rates, Km, Vmax, and inhibition modes.
  • Understanding of enzyme kinetics and the Michaelis-Menten equation
  • Familiarity with Lineweaver-Burk plot analysis
  • Experience with spectrophotometry and absorbance measurement
  • Knowledge of preparing calibration curves and interpreting standard curves
  • Learn how to construct and interpret Lineweaver-Burk plots for enzyme kinetics
  • Study the effects of various inhibitors on enzyme activity
  • Explore the principles of spectrophotometry and its applications in biochemical assays
  • Investigate methods for calculating initial reaction rates in enzyme assays
Biochemists, laboratory technicians, and students studying enzyme kinetics or conducting experiments involving enzyme inhibition and analysis of reaction rates.
Sitix
Somebody please help me.
Practical:
A calibration graph should be prepared by taking 0.0 (zero, blank), 1.0, 2.0 and 3.0 ml aliquots of an aqueous solution containing both 1.67 mM D-glucose and 1.67 mM D-fructose. Add distilled water to maket it 3 ml. Add 1 ml DNS reagent. Incubate 5 min. Add 3 ml distilled water.Measure with spectrophotometer 540 nm
Do the same with inhibitors
Results:
Standard curve
ml glucose/fructose Absorbance
0,----- 0.0
1,----- 0.69
2,----- 1.44
3,----- 2.15
absorbance
ml sucrose No inhibitor + fructose +urea
0------------0.03------ 0.63------ 0.02
0.25-------- 1.08------ 0.97- ----- 0.43
0.5--------- 1.15------ 1.17- ----- 0.71
1.0--------- 2.29------ 1.71------- 1.02
1.5--------- 2.20------ 2.11------ 1.14
Questions
The standard curve drawn in terms of the molar concentration (in the 3 ml samples; not the volumes of standard mixture) of inverted sucrose (glucose + fructose) in the assay tubes.
From your results, determine:
1) the initial rates of reactions in units of mmole min-1 (ml diluted enzyme)-1
2) the Km and Vmax of the diluted enzyme, using the Lineweaver-Burk plot
3) determine the mode of inhibition for fructose and urea, and their Ki values using the Lineweaver-Burk plot
Please help me
I read around a lot but I just cannot start it
I wanted to use C1v1=C2V2 But I don't have the concentration
Please somebody at least tell me how to start it
Rather sketchily described.
A standard curve is an absorbance plotted against known concentrations of something. When you have a standard curve you can then use it to determine the unknown concentrations e.g. resulting from an enzyme reaction, by measuring absorbance. Your first table looks to be the calibration curve and looks reasonably linear.
Your second table might be the enzyme kinetic experiment, but you do not describe it. Was fructose the inhibitor? Does the third column represent measurement in the presence of an (unstated) constant concentration of fructose? What has urea to do with it?
Probably you have data that tells you the amount of (fructose + glucose) made in a certain time by hydrolysis of sucrose at varying concentrations. You say you don't, you would have to know the concentration of the sucrose solution you started with. You'd know that either from having weighed it out and made up the stock solution, or someone told you. You then know the concentration in the experiments since you pipetted various volumes to make a total volume you should also know.
Thanks for your answer
Sorry panicked a little.
It is an enzyme kinetics practical with inhibitors fructose and urea.
I have the data that tells me the amount fructose/glucose and I put it in my question.
I have figured out a lot by myself but thanks for your answer.
