I this mathematically 'legal'?
  • Context: Undergrad
  • Thread starter Thread starter blahblah8724
The discussion revolves around the mathematical validity of manipulating the modulus of complex numbers, specifically whether transforming the 'modulus of the square' into the 'square of the modulus' is permissible. Participants explore the implications of this transformation using the triangle inequality and properties of complex numbers.
  • One participant questions the validity of converting |(z + i)^2| into (|z+i|)^2, suggesting this transformation may not be allowed.
  • Another participant proposes testing the claim through direct computation to explore its validity.
  • A participant notes that the function f(x) = x^2 is increasing on (0, ∞), which may provide insight into the discussion.
  • Concerns are raised about the conditions under which a >= b implies a^2 >= b^2, particularly when b could be negative.
  • Some participants highlight that the conclusion reached by the original poster is correct, but only when considering both inequalities from the triangle inequality.
  • One participant reflects on whether the reasoning for squaring terms was implicit in their initial approach.
  • Another participant asserts that the squaring of terms does not affect the comparison of positive numbers, allowing the same inequality for the squares.
  • A participant explores the relationship between |z|^2 and |z^2|, concluding that they are indeed equal through a specific example.
  • It is mentioned that the property |z1 * z2| = |z1| * |z2| is a more general property of the modulus.
Participants express differing views on the validity of the transformation of moduli and the conditions under which certain inequalities hold. There is no consensus on the initial claim, and multiple perspectives remain regarding the mathematical reasoning involved.
Participants acknowledge the importance of conditions such as positivity in the application of certain mathematical rules, indicating that the discussion is nuanced and dependent on specific assumptions.
blahblah8724
When trying to bound this complex number using [itex]|z| = R[/itex], I turned the 'modulus of the square' into the 'square of the modulus', is this allowed?!
[itex]|(z + i)^2|[/itex]
[itex]= (|z+i|)^2[/itex] 'modulus of the square' into the 'square of the modulus'
[itex]\geq (|z| - |i| )^2[/itex] triangle inequality variation
[itex]= (|z| - 1)^2[/itex]
[itex]= (R - 1)^2[/itex]
Help would be appreciated!
Why don't you test it by direct computation ?
The key is to note that the function [itex]f(x) = x^2[/itex] is increasing on [itex](0, \infty)[/itex] in the reals. Does that help?
Because, while finding a counterexample would show it is NOT true, getting any number of examples where it does work would not prove it is true.
Are you aware of the polar representation of complex numbers (aka Euler's formula)?
That is, [itex]z=re^{i\phi}[/itex], where [itex]|z|=r[/itex].
Perhaps you might consider what |z2| would be versus |z|2...?
Yes, blahblah8724, your reasoning is correct.
Technically this is not allowed. The rule used here is seemingly a >= b --> a^2 > b^2 which is valid as a rule only if a,b > 0. In this case b= |z|-|i| could be negative. However, the triangle inequality also gives |z+i| >= |i|-|z|, so the conclusion is correct, but only after using both inequalities. Essentially: (a >= b and a >= -b) --> a^2 >= b^2.
Good point. Although here it turns out you arrived at a correct inequality, as 'disregardthat' pointed out, this is due to:
[tex] \vert z_{1} - z_{2} \vert \ge \vert \vert z_1 \vert - \vert z_2 \vert \vert \ge 0[/tex]
I was under the impression that that reasoning was already implicit, and was the reason for working with the squared terms in the first place.
The squaring of the terms had nothing to do with it. The fact that we compare positive numbers (under the squaring operation) allows us to write the same inequality for the squares as well.
hmm...is it true that [itex]|z|^2 = |z^2|[/itex]?
well, I'm notoriously weak-minded, so i will just see if this works:
let [itex]z = a+ib[/itex]. then [itex]|z|^2 = (\sqrt{a^2 + b^2})^2 = a^2 + b^2[/itex].
now [itex]|z^2| = |(a+ib)(a+ib)| = |(a^2 - b^2) + i(2ab)| = \sqrt{(a^2 - b^2)^2 + (2ab)^2}[/itex]
[tex]= \sqrt{a^4 - 2a^2b^2 + b^4 + 4a^2b^2} = \sqrt{a^4 + 2a^2b^2 + b^4} = \sqrt{(a^2+b^2)^2} = a^2 + b^2[/tex]
huh. i guess so.
It follows from a more general property of the modulus:
[tex] \vert z_1 \, z_2 \vert = \vert z_1 \vert \, \vert z_2 \vert[/tex]
  • · Replies 27 ·
