How Can Man Take 2 Pills to Stay Alive?
  • Context: High School
  • Thread starter Thread starter T@P
    Brain
The discussion revolves around a hypothetical scenario where a man must take two pills from two different bottles to stay alive, but he spills the pills and is left with a mix of pills on the floor. Participants explore various creative solutions to ensure he can still take the required medication despite the challenges presented by the situation.
  • One participant suggests calling a doctor to get more pills as a straightforward solution.
  • Another proposes cutting all pills into twenty pieces to take one piece from each, but raises concerns about the practicality of cutting pills accurately.
  • A different participant mentions the possibility of dissolving the pills in water and weighing the mixture to determine the correct dosage, highlighting the importance of precision in medication.
  • There is a reiteration of the cutting method, suggesting cutting pills into ten pieces instead of twenty, but still questioning the feasibility of this approach.
  • One participant emphasizes that pills must be soluble since they are taken with water, arguing against the cutting method due to imprecision and the risk of overdose.
Participants express various ideas and solutions, but there is no consensus on the best approach. Several methods are proposed, each with its own set of challenges and uncertainties.
Participants note limitations regarding the practicality of cutting pills and the need for precise measurements, as well as the assumption that the pills are soluble.
This discussion may be of interest to those exploring problem-solving strategies in hypothetical scenarios, particularly in the context of medication and dosage accuracy.
T@P
a man has two bottles, each containing ten pills. in order to stay alive, he must take two pills (one from each bottle) simlutaneously in order to stay alive. any other combination is fatal. unfortunately, he spills both bottles, and as a reslut has 2 pills in one bottle and none in the other, but 18 on the floor. he disovers that they all look the same, and even when he pulls out his analytical scale, he finds that they weigh the same.
how does he take his medicine? i know the answer, just looking for ideas/ cool solutions.
Mathematics news on Phys.org
call the doctor, and tell him to send the guy some more pills. :smile:
One way would be to cut all the pills into twenty pieces each, and take one piece from each pill.
There's a couple problems with this solution, though. You need twenty pill bottles because you can't mix any of the pills. Can you cut a pill into twenty equal pieces? There's a limit to how many times you can fold a dollar bill, so I'm sure there's a limit on how many times you can cut a pill without it just virtually disintegrating.
Or you could see if the pills dissolved, but then you wouldn't know how much to drink and might overdose.
But if you ground up a pill and weighed it (with your analytical scale), then ground up all the rest and mixed it all together thourougly, then you'd know how much of the powder to take.
Almost there. Rememeber he needs 2 pills a day. So, cut the pills into just ten pieces each, and take one piece from each pill.
actually the idea is basically to disolve the pills in water and use your analytical scale to find the corect amount you need. the reason you sohuld be able to disolve them is the simple fact that they are pills; since you swallow them with water they must be somehow solubale. cutting pills is imprecise, and remember he will die if he doesn't get exactly the right amount :) (actually as bob said their is a limit to how many times you can cut a pill so this is impractical that way too)
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 47 ·
  • · Replies 62 ·
13K
