Solving Two Physics Problems: Weighing Rocks and Steel Barbells
The discussion revolves around two physics problems involving buoyancy and density. The first problem concerns a geologist weighing a rock specimen in air and water to determine its solid volume fraction, while the second problem involves a bodybuilder lifting a steel barbell underwater and calculating the force exerted.
  • Participants explore the application of Archimede's Principle and the relationship between mass, density, and volume. Questions arise about how to utilize the known density and weight measurements without having the mass explicitly stated.
Some participants have offered hints regarding the relationships between mass, density, and volume. There is an ongoing exploration of how to apply these concepts to the problems, with no clear consensus yet on the methods to be used.
Participants note the lack of explicit mass information for the first problem and express uncertainty about how to proceed with the calculations based on the given data.
SnowOwl18
Alright, these two problems are driving me nuts:
1. ---To verify her suspicion that a rock specimen is hollow, a geologist weighs the specimen in air and in water. She finds that the specimen weighs twice as much in air as it does in water. The solid part of the specimen has a density of 5.10×103kg/m3. What fraction of the specimen's apparent volume is solid?----
I think that this involves Archimede's Principle because she floats the rock in water to find displacement... the equation is (magnitude of buoyant force)= (weight of displaced fluid) ...but I don't see how I can use that equation..
Also this problem:
----A bodybuilder is holding a 29.9kg steel barbell above her head. How much force would she have to exert if the barbell were lifted underwater?---
It doesn't seem like much information to work with...maybe i'd need to use archimede's principle here as well, to find the weight displacement...but again, I'm not sure how to do that.
Thanks for any help on these problems :)
HINT: The mass of an object is the product of its density and volume.
hmm so mass= density x volume. For the first problem I know the density and that the weight in air is twice that of in water...how do I use that equation if I don't actually know the mass though? Thanks for you're help so far :)
Does this help?
[tex]Submerged \ Weight = Dry \ Weight - \rho_{water} \ g Volume_{hollow}[/tex]
[tex]Dry \ Weight = \rho_{rock} \ g \ Volume_{rock}[/tex]
28K
