| New Reply |
Is a finite function with finite Fourier transform possible? |
Share Thread | Thread Tools |
| Dec3-11, 06:03 PM | #1 |
Clarification: I have seen in quantum mechanics many examples of wavefunctions and their Fourier transforms. I understand that a square pulse has a Fourier transform which is nonzero on an infinite interval. I am curious to know whether there exists any function which is nonzero on only a finite interval, whose Fourier transform is also nonzero on only a finite interval. Is it impossible? I have not been able to find any theorem about it. If an example exists I would be very interested in seeing it because I think it would make a great wavefunction to think about.
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Dec3-11, 06:17 PM | #2 |
Recognitions:
Hm, I haven't seen any theorems describing exactly this situation, but I suspect it isn't possible. The frequency and time (or momentum and position) variables of the fourier transform are conjugate variables whose widths are roughly inversely to each other - that is, the more peaked a function is in one variable (e.g., time), the wider the corresponding transform will be. (For an example, a delta function is in some sense "infinitely peaked", and its fourier transform is a constant which is infinitely wide, and vice versa).
In fact, fourier transform variables are subject to an uncertainty principle. See here. I suspect that if you had a function with support only on a finite interval and you assumed that the fourier transform also only had finite support that you would violate the uncertainty inequality, but I don't know for sure. |
| Dec4-11, 05:12 AM | #3 |
Recognitions:
| New Reply |
| Tags |
| domain, fourier transform, wavefunction |
| Thread Tools | |
Similar Threads for: Is a finite function with finite Fourier transform possible?
| Finite element method versus intergrated finite difference for complex geometries? | Differential Equations | 6 | ||
| Why can finite elements handle complex geometries, but finite differences can't? | Differential Geometry | 1 | ||
| Finite Element vs. Finite Volume | Engineering, Comp Sci, & Technology Homework | 1 | ||
| finite expectation value <-> finite sum over Probabilties | Calculus & Beyond Homework | 3 | ||
| Fluid Dynamics (finite difference or finite volume) | Advanced Physics Homework | 1 | ||
