What Causes Voltage Drops Across an Inductor in an R-L-C Series Circuit?
  • Thread starter Thread starter Moore65
    Series
The discussion focuses on calculating voltage drops across an inductor in an R-L-C series circuit driven by an AC source with an EMF of 110.0V at 60.0 Hz. The circuit parameters include a resistance of 20.0 Ohms, an inductance of 5.0 * 10^-2 H, and a capacitance of 50.0 µF. The impedance is calculated to be 65Ω, leading to a current of 1.69A. The voltage drop across the inductor at t=0 is determined to be 33.8V, while at the first maximum EMF (t=t1), the voltage drop is calculated to be 32.7V.
  • Understanding of R-L-C series circuits
  • Knowledge of AC circuit analysis
  • Familiarity with Ohm's Law
  • Ability to calculate impedance, inductive reactance, and capacitive reactance
  • Learn how to calculate impedance in R-L-C circuits using Z = √(R^2 + (XL - XC)^2)
  • Study the effects of phase difference in AC circuits
  • Explore the voltage divider rule in R-L-C circuits
  • Investigate the behavior of inductors and capacitors in transient analysis
Electrical engineering students, circuit designers, and anyone interested in understanding AC circuit behavior and voltage drop calculations in R-L-C series circuits.
Moore65
Trouble with the R-L-C series. Please Help!
I'm having trouble trying to understand this problem.
The R-L-C series circuit is driven with a AC source with EMF=Vo*sin(wt) where Vo=110.0V and f=60.0 Hz. If R = 20.0 Ohms, L=5.0 * 10^-2 H, and C=50.0uF, find the potential drops across the inductor at to=0 and at a time t1=the first time after to that the EMF reaches a maximum.
The current moves through the circuit first through the resistor, then through the capacitor, and finally through the "L" before completely the cicuit.
I'm not really sure what to do, can anyone help?
Hi there,
I can definitely try to help you with this problem. First, let's break down the problem into smaller steps.
Step 1: Find the impedance of the circuit
We know that the impedance of a series circuit is given by the formula Z = √(R^2 + (XL - XC)^2). In this case, XL is the inductive reactance and XC is the capacitive reactance. We can calculate these values using the formulas XL = ωL and XC = 1/ωC, where ω = 2πf. Plugging in the given values, we get XL = 6Ω and XC = 63.7Ω. Now, we can calculate the impedance as Z = √(20^2 + (6 - 63.7)^2) = 65Ω.
Step 2: Calculate the current
Using Ohm's law, we can calculate the current in the circuit as I = V/Z, where V is the source voltage. Plugging in the given values, we get I = 110/65 = 1.69A.
Step 3: Find the potential drop across the inductor at t = 0
At t = 0, the current is just starting to flow through the circuit. This means that the voltage drop across the inductor is equal to the voltage drop across the resistor, since there is no voltage drop across the capacitor yet. Using Ohm's law, we can calculate the voltage drop across the resistor as VR = IR = 1.69 * 20 = 33.8V. This means that the voltage drop across the inductor at t = 0 is also 33.8V.
Step 4: Find the potential drop across the inductor at t = t1
At t = t1, the EMF reaches its maximum, which means that the voltage drop across the capacitor is also at its maximum. This means that the voltage drop across the inductor is now equal to the voltage drop across the resistor and the capacitor in series. Using the voltage divider rule, we can calculate the voltage drop across the inductor as VL = VR * XC/(XL + XC) = 33.8 * 63.7/(6 + 63.7) = 32.7V.
I hope this helps you understand the problem better and find the potential drops across the in
  • · Replies 21 ·
  • · Replies 52 ·
14K
