Would the light bulb light up from the electromagnetic wave?
The discussion revolves around the interaction of electromagnetic waves with a light bulb positioned on a wire, exploring whether the bulb would light up under various orientations relative to the electric and magnetic fields. The subject area includes concepts from electromagnetism and wave behavior.
  • Participants discuss the conditions under which the bulb might light up based on its orientation to the electric field. Questions are raised about the effects of shifting the wire and rotating it relative to the fields. Some participants also consider the implications of polarization and the scale of the wire compared to the wavelength of the electromagnetic wave.
The discussion is active, with various interpretations being explored regarding the bulb's brightness under different scenarios. Some participants have provided insights into the nature of electromagnetic fields and their interaction with conductors, while others have questioned assumptions about the setup and the nature of the waves involved.
There are mentions of the need for clarity regarding whether the electromagnetic radiation is treated as a plane wave and how that might affect the outcomes discussed. The original poster's questions suggest a focus on understanding the principles rather than seeking direct answers.
nake9534
In the picture below
http://www.geo.mtu.edu/rs/back/spectrum/e_mag.gif
a bulb is placed on a wire parallel to the direction of the electric field. The bulb is directly on the x-axis where the two waves cross each other.
1. Would the bulb glow when the wire is parallel to the direction of the electric field?
The wire containing the bulb is now shifted up a distance on the plane of the electric field
2. Would the brightness of the bulb be greater than, less than, or equal to that of the brightness in 1?
Now imagine that the wire with the bulb is rotated 45 degrees so that it is now oriented between the electric and magnetic fields
3. Would the brightness of the bulb be greater than, less than, or equal to that of the brightness in 1?
// My Responses
1. I think that the bulb would light up because the wire is parallel to that of the electric field and perpendicular to that of the magnetic field.
2. I think that the bulb would have the same brightness as in the first question because the orientation of the current carrying wire does not change.
3. I think that the bulb would be less bright than that in case 1 because neither field is in the optimum location to light the bulb.
A good explanation is much appreciated
Thanks
Edit: Bad info below! Leaving here to keep the thread together.
Couple of things here.
1. The diagram of the magnetic and electric fields of a photon are simply a visualization of how the fields work, a graph of the interaction of the fields. There is no "plane", the effect is in every direction. Both the magnetic and electric fields alternate from + to - and back over time in accordance with the frequency of the light.
2. A wire is MUCH MUCH MUCH bigger than a photon is. Even if there was a plane you could not align the wire.
An electric current is induced onto a conductor of comparable length to the wavelength of the propagating wave.
An electrical load would experience this current if it were connected, for example, across the gap between two such aligned conductors, or between a conductor and a 'ground'.
The field would have to be very high to induce enough current to light a light bulb, but there would be a current. This is how radio signals are received by an antenna. It's why your TV or radio antenna has to be vertical or horizontal if the transmitter is also vertical or horizontal.
What do you think 'polarisation' is, if there is no 'plane'? How do antennas work?
Yeah, I guess you are right. I was thinking that the polarization had to do with something else, not the EM fields.
In retrospect I now remember several threads on photon polarization I've been in before. Guess I had a brain fart.
// My Responses
Thanks
In addition to cmb's comments...
The answer to #2 would depend on whether the problem stated that the EM radiation was a plane wave, or if its amplitude falls off away from the axis of travel. Does the problem statement of this schoolwork question say anything about that?
