Bandwidth efficiency in m - ary psk
The discussion focuses on the bandwidth efficiency of M-ary Phase Shift Keying (PSK). The initial formula presented for bandwidth efficiency is Rb/B = log2(M), where Rb is the bit rate and B is the bandwidth. However, Simon Haykin's reference indicates that the correct bandwidth efficiency is (log2(M))/2, leading to the conclusion that the channel bandwidth required for M-ary PSK is B = 2/T, with T defined as Tb(log2(M)) and Rb = 1/Tb.
  • Understanding of M-ary PSK modulation techniques
  • Familiarity with bit rate (Rb) and symbol rate (Rs)
  • Knowledge of logarithmic functions, specifically log base 2
  • Basic concepts of channel bandwidth and signal processing
  • Research the derivation of bandwidth efficiency in digital modulation schemes
  • Study Simon Haykin's "Digital Communications" for in-depth understanding of M-ary PSK
  • Explore the implications of bandwidth efficiency on communication system design
  • Learn about the impact of symbol rate on overall system performance in PSK
Engineers and researchers in telecommunications, students studying digital communication systems, and professionals involved in optimizing modulation techniques for efficient bandwidth usage.
erece
In M-ary psk
Rb=Rs*log M log with base 2
Rb- bit rate
Rs - symbol rate
then bandwidth required for passband signal is B=Rs
and bandwidth effeciency = Rb/B=log M log with base 2.
Is the above formula for bandwidth efficiency correct ?
But in simon haykin it is given that bandwidth efficiency is (log M )/2 log with base 2
The channel bandwidth required to pass M-ary PSK is B=2/T
Now, T = Tb (log2 M) and Rb = 1/Tb
So rho = Rb/B = (log2 M) /2
