Proving f(0)=f(1) in the Sierpinski Topology with a Continuous Function
  • Thread starter Thread starter Ted123
The problem involves the Sierpinski topology on the set X = {0, 1} and a continuous function f: X → ℝ. The goal is to show that f(0) = f(1).
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of continuity for the function f and consider the consequences of assuming f(0) ≠ f(1). There are discussions about the preimages of sets under f and their properties in relation to the topology.
The discussion is ongoing, with participants examining the validity of their assumptions and reasoning. Some have suggested that assuming f(0) ≠ f(1) leads to contradictions regarding the continuity of f, while others question the correctness of these conclusions and the definitions involved.
There is an emphasis on the definitions of closed and open sets within the Sierpinski topology, as well as the continuity of functions in this context. Participants are also addressing the potential for misunderstanding regarding the properties of the function f.
Ted123
Let [itex]X=\{0,1\}[/itex] with the Sierpinski topology [itex]\tau = \{ \emptyset , \{0\} ,\{0,1\} \}[/itex].
Suppose [itex]f:X\to \mathbb{R}[/itex] is continuous.
Show [itex]f(0)=f(1)[/itex].
[Potentially useful observation: [itex]\{f(0)\}[/itex] is closed in [itex]\mathbb{R}[/itex].]
[itex]f:X\to\mathbb{R}[/itex] is continuous [itex]\iff[/itex] for every open (closed) set [itex]A\subseteq \mathbb{R},\;f^*(A)[/itex] is open (closed) in [itex]X[/itex].
How to show f(0)=f(1)?
Suppose the contrary, and find an open set whose preimage is {1}.
Does [itex]f^*(\{0\}) = \{1\}[/itex]?
Who could say until you define what f is?? Follow Citan Uzuki's advice and define f(0)=a and f(1)=b where a and b are unequal real numbers. Is f continuous?
So [itex]\{a\} \subseteq \mathbb{R}[/itex] and [itex]\{b\} \subseteq \mathbb{R}[/itex] are closed, and [itex]f^*(\{a\})=\{0\} \subseteq X[/itex] is closed in [itex]X[/itex] but [itex]f^*(\{a\})=\{1\}[/itex] is not closed in [itex]X[/itex] so [itex]f[/itex] is not continuous - contradiction; therefore [itex]f(0)=f(1)[/itex]?
^ That should say [itex]f^*(\{b\})=\{1\}[/itex] but I can't find an edit button!
Right. Now to finish up show that if a=b then f IS continuous.
That approach will work, but you're doing it backwards. {0} is not closed in X, because its complement is {1}, which is not in the topology on X. So the conclusion that f is not continuous comes from the fact that f*({a}) = 0, not the fact that f*({b}) = 1.
Yeah, actually I didn't notice, but you right. My 'Edit' button disappeared for a while yesterday. Seems to be back now. At least for me. Citan Uzuki is also right. I didn't notice you'd swapped the open and closed either. Guess I should read more carefully.
If we have a contradiction after supposing [itex]a\neq b[/itex] doesn't that mean we must have [itex]a=b[/itex]?
No! All you've shown is that if a not equal b is then f is not continuous. How can that be a proof that if a=b then f is continuous? There might not be ANY continuous functions.
But we're assuming all along that [itex]f:X\to \mathbb{R}[/itex] is continuous (as the question tells us this!)
Ok, this is really not my day. You are right. I thought you had to prove f continuous iff a=b. I saw the double arrow in your original post and fixated on it.
  • · Replies 20 ·
  • · Replies 58 ·
  • · Replies 17 ·
