New Reply
Vertical mass-spring system - force or energy?
Share Thread Thread Tools
Dec7-11, 08:35 PM   #1
A lot of problems I see have vertical mass-spring systems, where a mass m hangs from a spring with spring constant k stretching it a distance D, and usually all but one of those quantities is known. But would you equate the forces or the energies, i.e. which is the correct equation to use: mg=kD or mgD = 1/2kD^2, because the two give different answers.
Which is correct? Why is the other incorrect?
Thank You
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Dec7-11, 08:47 PM   #2
The first one is correct in general (i mean, unless the spring itself has mass, but that would be ridiculous!). It's just Hooke's Law.
The second one is more complex. Imagine quickly hooking on the weight: the weight is going to start oscillating on the spring, with the center of oscillation being at the point given by mg = kD. However, at that point, the weight's going to have kinetic energy, which you haven't accounted for. Your equation has no kinetic energy: the only way that could happen would be if you gently lowered the block into place. If you do that, you'd be doing negative work on the block, so conservation of energy would not be valid.
If you want to work it out, conservation of energy still holds (in a way) for vertical springs! In fact, you can completely ignore GPE and just write KE + EPE = constant. The only difference is that you have to measure x in (1/2)kx^2 from the new equilibrium point, given by mg = kD. If you want, you can work that out and see why it's true; the new way of defining x accounts exactly for the GPE chance.
New Reply
Tags
energy, force, mass, spring, vertical
Thread Tools
Similar Threads for: Vertical mass-spring system - force or energy?
Thread Forum Replies
Oscillatory motion (vertical spring-mass system) General Physics 7
Spring mass system with applied force kinetic energy Classical Physics 1
Energy in a spring-mass system Introductory Physics Homework 3
vertical mass-spring system Introductory Physics Homework 11
Energy in a vertical spring mass system Introductory Physics Homework 2
