Rotation with constant acceleration
The discussion focuses on calculating the final rotational speed of a flywheel with a mass of 40 kg and a diameter of 75 cm, initially spinning at 500 rpm, after experiencing friction over 30 seconds. The wheel completes 200 revolutions during this time, indicating a deceleration due to friction. By applying the rotational kinematic equation, specifically x = x_0 + v_0t + 1/2at^2, users can determine the acceleration and subsequently the final speed of the flywheel.
  • Understanding of rotational motion and kinematics
  • Familiarity with the concept of angular velocity and its units
  • Knowledge of the rotational analogs of linear equations of motion
  • Basic proficiency in solving equations involving acceleration
  • Learn how to apply the rotational kinematic equations in different scenarios
  • Study the effects of friction on rotational motion
  • Explore the conversion between rpm and radians per second
  • Investigate the principles of angular momentum and its conservation
Students and professionals in physics, mechanical engineering, or anyone interested in understanding the dynamics of rotating systems and the effects of friction on motion.
gunnar
A flywheel has mass 40 kg and diameter 75 cm is spinning at 500 rpm. During 30 sec the wheel slows down due to friction. The wheel makes 200 complete revolutions during the 30 sec.
At what rate is the wheel spinning at the end of the 30 sec?
Can somebody help with this problem please?
Use the kinematic equations for uniform acceleration to solve for the acceleration, and then the final speed. For example, you can start with the rotational analog of this equation: [itex]x = x_0 + v_0t + 1/2at^2[/itex].
Thank's a lot. Really saved me there.
  • · Replies 16 ·
12K
  • · Replies 60 ·
