Shoot a bullet at a half-infinite isotropic elastic solid.
The discussion centers on the behavior of longitudinal and transverse waves generated by a bullet impacting a half-infinite isotropic elastic solid in spherical coordinates. It is established that longitudinal waves are of maximum intensity in the theta = 0 direction, while transverse waves peak in the theta = 90 degrees direction. The participants explore the theoretical possibility of altering the properties of the isotropic elastic solid to reduce or eliminate longitudinal waves without affecting transverse waves. The introduction of additional dimensions, specifically a fourth spatial dimension, is proposed as a potential solution to achieve this goal.
  • Understanding of wave propagation in elastic materials
  • Familiarity with spherical coordinates and their applications
  • Knowledge of isotropic elastic solid properties
  • Basic concepts of higher-dimensional physics
  • Research the properties of isotropic elastic solids in higher dimensions
  • Learn about wave propagation in 4D space
  • Investigate methods to manipulate wave types in elastic materials
  • Explore the concept of circularly polarized waves and their generation
Physicists, engineers, and researchers interested in wave mechanics, particularly those exploring advanced concepts in elastic materials and higher-dimensional physics.
Spinnor
Say we shoot a bullet that travels in the theta = 0 direction (we are in spherical coordinates). Say the bullet strikes and sticks to a half-infinite isotropic elastic solid that begins at the theta = 90 degrees plane. Is it true that longitudinal waves generated by the bullets impact will be of maximum intensity in the theta = 0 direction and that transverse waves generated by the bullets impact will be of maximum intensity in the theta = 90 degrees direction?
Is there any way, however contrived, that we can reduce or eliminate the longitudinal waves generated by the bullets impact by changing the properties of the isotropic elastic solid while at the same time leaving the transverse waves unaffected?
Thanks for any help!
If we add an extra dimension I think we can get close to my requirements,
"Is there any way, however contrived, that we can reduce or eliminate the longitudinal waves generated by the bullets impact by changing the properties of the isotropic elastic solid while at the same time leaving the transverse waves unaffected?"
Let us have an 3D infinite isotropic elastic solid which lies in 4D space. Let w be the extra spatial dimension. At equilibrium let the solid be located at w = 0. Let the gun be located at the point (0,0,0,L). Let the bullet be fired so that it only has momentum in the -w direction. Let the bullet strike and stick to the infinite solid at the point (0,0,0,0). A transverse wave propagates outward from the point (0,0,0,0)? There are no longitudinal waves?
Let us add an extra dimension v. Let there be two guns that shoot bullets in the v and w directions which strike and stick to the solid. With two guns we can produce circularly polarized transverse waves with the right gun shots?
23K
  • · Replies 264 ·
33K
  • · Replies 0 ·
  • · Replies 94 ·
15K
