What is the Gravity GPM for a 1 pipe and 83 gal. fuel transfer tank?
  • Context: Undergrad
  • Thread starter Thread starter docsmith
    Gravity Pipe
The discussion focuses on calculating the gravity flow rate in gallons per minute (GPM) for an 83-gallon fuel transfer tank using a 1-inch pipe. The user seeks to understand the GPM at various tank capacities: 100%, 50%, and 25%. Key insights include the use of Bernoulli's equation to derive flow velocity and the recommendation to use a "full port" ball valve for improved flow. The discussion emphasizes the importance of venting the tank outside the trailer for safety.
  • Understanding of Bernoulli's equation and fluid dynamics
  • Knowledge of volumetric flow rate calculations
  • Familiarity with the properties of fuel, including density
  • Experience with plumbing components, specifically ball valves and hose fittings
  • Research "Bernoulli's equation applications in fluid flow" for deeper understanding
  • Learn about "full port vs. standard port ball valves" and their impact on flow rates
  • Investigate "venting requirements for fuel tanks" to ensure safety compliance
  • Explore "calculating flow rates in different pipe diameters" for comparative analysis
This discussion is beneficial for engineers, DIY enthusiasts, and anyone involved in fuel transfer systems, particularly those using gravity flow methods in confined spaces like trailers.
docsmith
Gravity GPM for 1" pipe
I am in the process of buying an 83 gal. fuel transfer tank. The tank is 48"L x 20"H x 20"W. Instead of buying pumps for filling up my 5 gallon gas tanks I was thinking about using gravity flow. The builder can install a 1" fitting at the base of the tank with a 1" hose. The tank is going inside an enclosed trailer so I am limited on how high I can build the tank. I can build the tank 2 feet off of the floor of the trailer plus the 9 inch clearance from the floor of the trailer to the ground level. I will be using a ball valve to turn it off and on. What is the gallons per minute when in use. I understand that the GPM will vary depending on the amount of gallons in the tank. What is the GPM at 100% capacity, 50% capacity and 25% capacity?
Thanks for your time and consideration.
Welcome to PF.
These formulas are good for estimating.
http://www.lmnoeng.com/Tank/TankTime.htm
Use a "full port" ball valve rather than a "standard port" for improved flow.
Try C = 0.5 in the formulas.
I have these (with some enhancements) programmed at work in MathCAD.
Let me know if you need any help !
A full solution requires the diimensions of the tank being filled and details about the hose and valve. But as a working solution the following apprach is probably adequate.
To solve this problem use Bernoulli's equation.
P +ρV2/2 + ρgh = HL
P is atmospheric pressure and in this case is a constant and can be ignored. Simplify by assuming Head Loss (flow resistance from hose and valve) is small and can be ignored.
So what you end up with is a term due to elevation head (ρgh) and a term due to flow (ρv2/2).
The elevation head term uses ρ the density of the fuel, gravity and the height of the fuel surface in the tank above the level in the 5 gallon tank. Basically the elevation head is converted to velocity head ρv2/2. The value of v is the velocity in the hose and ρ is still the density of the fuel.
So the equation becomes v = sqrt(2gh) since the density terms cancel out.
Finally the volumetric flow (gpm) can be found by multiplying the velocity v by the area of the hose.
BTW, Please ensure that you vent the tank outside the trailer for safety.
  • · Replies 22 ·
  • · Replies 39 ·
17K
  • · Replies 19 ·
11K
