How do two aligned Polaroids transmit light in Grade 12 physics problems?
The discussion centers on the transmission of light through two aligned Polaroids in Grade 12 physics problems. It is established that non-ideal Polaroids transmit 40% of nonpolarized light, and when two such Polaroids are aligned, they transmit 32% of the incident light. This conclusion is derived using Malus' Law, which indicates that the intensity of transmitted light is affected by the absorption characteristics of the Polaroids. The absorption factor of 0.8 for each Polaroid leads to the final calculation of 32% transmission.
  • Understanding of Malus' Law in optics
  • Knowledge of light polarization concepts
  • Familiarity with the behavior of non-ideal polarizers
  • Basic mathematical skills for percentage calculations
  • Study the implications of Malus' Law in various optical systems
  • Research the properties and applications of non-ideal polarizers
  • Explore advanced topics in light polarization and its effects on imaging
  • Learn about the mathematical modeling of light transmission through filters
Students in Grade 12 physics, educators teaching optics, and anyone interested in the principles of light transmission and polarization.
moonpearl
Grade 12 physics problems :(
One question:
Because of absorption, a Polaroid will actually transmit 40% of nonpolarized light incident on it. Two such Polaroids with their axes aligned will transmit
a. 16%.
b. 24%.
c. 30%.
d. 32%.
e. 40%.
The answer is 32% and I have no cue why. My textbook doesn't say anything and since I am taking a conceptual physics course, I have no formulas to work with. Does anyone know why this is the answer?
Thanks,
LA
An ideal polarizer will let 50% of the unpolarized light through.
These polarizers in the problem are not ideal, they absorb a fraction/percentage of the light they should let through. Can you find this fraction to be 0.8?
After that, since the light which went through the first polarizer is now linearly polarized in the direction of the second polarizer, the second polarizer should let all light through if it was ideal. But it again stops 80% if the light which is incident upon it.
Hi LA, understanding polarization can be a challenging concept in physics. In this case, the answer can be found by applying Malus' Law, which states that the intensity of light transmitted through two polarizing filters is equal to the intensity of the incident light times the cosine squared of the angle between the filters. In this problem, the angle between the two polarizing filters is 0 degrees (since their axes are aligned), so the cosine of 0 degrees is 1. Plugging this into the equation, we get: I = (40%)(1^2) = 40%. However, the question is asking for the percentage of nonpolarized light transmitted, so we need to multiply this by 100% - which gives us 40% x 100% = 40%. Therefore, the correct answer is 40% x 40% = 16%, which is option a. Hope this helps clarify the solution for you. Keep up the good work in your conceptual physics course!
  • · Replies 17 ·
  • · Replies 56 ·
