Proving Prime Numbers: Understanding the Non-Divisibility Theorem in Mathematics
  • Thread starter Thread starter Hoovilation
    Primes Proofs
The discussion revolves around proving properties related to prime numbers, specifically focusing on the non-divisibility theorem. The original poster seeks assistance in demonstrating that the product of two positive integers less than a prime number is not divisible by that prime.
  • The original poster attempts to use prime factorization to prove the statement but recognizes this leads to circular reasoning. They also present an alternative problem regarding distinct prime numbers and their products.
Some participants have provided guidance, suggesting that the definition of prime numbers can be utilized to support the original poster's reasoning. However, the discussion remains open with various interpretations being explored.
The original poster notes constraints on using certain theorems and definitions related to prime factorization, which are considered circular in this context.
Hoovilation
Hello everyone,
My first post on these forums and I was wondering if I could have some assistance/direction with a problem:
Prove that if p is a prime number and a and b are any positive integers strictly less than p then a x b is not divisible by p.
The first thing I thought to myself was to break down a and b into primes and then show that since a and b are less than p and p is a prime that a x b cannot be divisble by p. This was not an acceptable answer since it is using circular reasoning which is based on this theorem. He talks about this below:
You are not allowed to use theorems such as all numbers can be uniquely prime factorized, or something along those lines that is actually based on this theorem. You are, however, certainly allowed to assume a prime factorization and can most certainly use the basic properties of addition / subtraction and multiplication / division, and what it means to be a prime, i.e., p when divided by any number a satisfying 1 < a < p leaves a non-zero remainder.
A common mistake is to assume that for any primes p1, p2, p3, p4 it is not possible to have p1 x p2 = p3 x p4 or some glorified version of this. This is simply a specific version of what needs to be proved.
If you can not seem to understand why this amounts to circular reasoning, drop the above problem and prove the following instead:
We are given this alternative but even for this I'm clueless and have no idea on where to start:
Prove that for any four distinct prime numbers p1, p2, p3, and p4, it is not possible that p1 x p2 = p3 x p4.
Any help is greatly appreciated, thanks!
-Hoov
You certainly should be able to use the fact that if ab is divisible by the prime number p, then either a or b is divisible by p. That only uses the basic definition of prime number.
In my text, that is the definition of a prime number. :smile:
That Hurkyl is good looking man, ain't he?
  • · Replies 178 ·
11K
  • · Replies 32 ·
