Producing Electrical Energy from Surf: A Cylinder and Turbine
The discussion centers on a method for generating electrical energy from ocean surf using a cylinder and a Wells turbine. The turbine is designed to rotate in a single direction regardless of air flow direction, allowing it to harness energy from the rising and falling water levels. The principle involves air movement within the cylinder caused by changes in water height, which drives the turbine consistently. Participants identified the turbine as a Wells turbine, which has been documented since the 1980s.
  • Understanding of basic fluid dynamics
  • Familiarity with turbine mechanics
  • Knowledge of renewable energy principles
  • Awareness of ocean energy conversion technologies
  • Research the design and functionality of Wells turbines
  • Explore ocean energy conversion systems
  • Investigate suppliers for Wells turbines suitable for small-scale applications
  • Study the principles of fluid dynamics in renewable energy systems
Engineers, renewable energy enthusiasts, and researchers interested in ocean energy technologies and turbine design.
hisham.i
Hello,
I was watching national geographic from 1 or 2 weeks, and they illustrated a way to produce electrical energy from surf.
I will try to explain the principle:
1- They brought a cylinder, and attached to it a turbine which is designed to rotate in only one direction independent of the direction of the air.
2- they put the other part in water.
when water height increase, the air inside the cylinder will flow in upward direction, and when the water height decrease the air inside the cylinder flow in downward direction, which causes the turbine to rotate in THE SAME DIRECTION.
I googled to find the name of this turbine which rotates in only one direction independent of the air direction but i didn't find it.
Any body knows its name?
Thanks
Thanks a lot, this what i was looking for :).
Now i will search to find some where to buy a small one of these turbines.
  • · Replies 45 ·
  • · Replies 26 ·
14K
  • · Replies 17 ·
10K
