Solve Series Convergence: Cauchy's n^{th} Root Criterion
  • Context: Graduate
  • Thread starter Thread starter quasar987
    Convergence
The discussion revolves around determining the convergence of the series \(\sum \left(\frac{n+4}{2n+3} \right)^{n\log n}\) using Cauchy's n^{th} root criterion. Participants explore various approaches and inequalities related to the series, focusing on the behavior of its terms as \(n\) becomes large.
  • One participant proposes using Cauchy's n^{th} root criterion and calculates the limit involving \(\left(\frac{n+4}{2n+3}\right)^{\log n}\).
  • Another participant suggests that for large \(n\), the terms resemble \((1/2)^{n\log n}\), indicating potential convergence, but acknowledges this is not precise.
  • A later reply challenges an earlier inequality, suggesting that bounding \(\frac{n+4}{2n}\) above by something less than 1 while keeping \(\log n\) in the exponent could be more effective.
  • Participants express uncertainty about the validity of certain bounds and inequalities used in the analysis.
Participants do not reach a consensus on the convergence of the series, and multiple competing views and approaches remain present throughout the discussion.
Some limitations include unresolved inequalities and the dependence on the behavior of logarithmic functions as \(n\) increases. The discussion does not settle on a definitive method for bounding the terms of the series.
quasar987
Does anybody see how to tell if this serie converges.
[tex]\sum \left(\frac{n+4}{2n+3} \right)^{nlogn}[/tex]
where log is the neperian logarithm.
This is my latest attempt...
Cauchy's [itex]n^{th}[/itex] root criterion:
[tex]\lim_{n \rightarrow \infty} \left( \left| \frac{n+4}{2n+3} \right|^{nlogn} \right)^{\frac{1}{n}} = \lim_{n \rightarrow \infty} \left(\frac{n+4}{2n+3}\right)^{logn}[/tex]
But
[tex]\left(\frac{n+4}{2n+3}\right)^{logn} < \left(\frac{n+4}{2n}\right)^{logn}[/tex]
And because for [itex]n \geq 5[/itex], [itex](n+4)/2n < 1[/itex] and because logx is a strictly increasing function, for [itex]n \geq 5[/itex], loge < logn and therefor
[tex]\left(\frac{n+4}{2n}\right)^{logn} < \left(\frac{n+4}{2n}\right)^{loge} < \frac{n+4}{2n}[/tex]
But that's unsignificant; I would have to bound it superiorly with a sequence that goes to 0.
when n is large, your terms "look like" [tex](1/2)^{n\log n}[/tex], which is very convergent. This isn't at all precise, but gives some ideas on how to proceed. Your terms are actually slightly larger than this similar looking thing. So I'd try a comparison test with something like [tex]a^{n\log n}[/tex] where a is a little bigger than 1/2.
Sorry, you can ignore my last post and finish off your root test. You get to
[tex]\left(\frac{n+4}{2n}\right)^{\log n}[/tex]
Your next inequality was no good-you bounded log(n) above by log(e).
Instead, try bounding [tex]\frac{n+4}{2n}[/tex] above by something less than 1 and leaving the log(n) in the exponent alone. Remember it's fine if your bound only holds for large n.
Ahhh, thanks shmoe!
  • · Replies 21 ·
  • · Replies 19 ·
