How much energy is released from an electron-positron annihilation?
  • Context: Graduate
  • Thread starter Thread starter thomas9459
    Annihilation Energy
The discussion revolves around the energy released during electron-positron annihilation, particularly considering the effects of electromagnetic forces. Participants explore theoretical aspects, experimental measurements, and the implications of quantum electrodynamics (QED) in this context.
  • One participant questions how the electromagnetic force affects the energy released during annihilation, suggesting that the energy should include both mass energy and electromagnetic attraction, yet finds the idea of infinite energy from Coulomb's Law problematic.
  • Another participant asserts that the question of energy release remains unanswered, emphasizing the need for clarity on the actual energy released during annihilation.
  • A layman participant proposes that annihilation results in no energy release, suggesting that the particles cancel each other out, which is challenged by others who reference conservation of energy.
  • One participant provides a formula for the total energy of the system, indicating that the energy released upon annihilation is consistent with conservation of mass-energy.
  • There is a discussion about the distance at which annihilation occurs, with one participant suggesting it happens at d=0, while another clarifies that annihilation occurs at varying distances based on electromagnetic interactions.
  • Another participant critiques the mixing of quantum mechanics with classical mechanics, asserting that annihilation is fundamentally an electromagnetic phenomenon and occurs based on the coupling constant rather than at a specific distance.
Participants express differing views on the nature of energy release during annihilation, with some questioning the role of electromagnetic forces and others defending the conservation of energy principle. The discussion remains unresolved regarding the specifics of energy calculations and the conditions under which annihilation occurs.
There are unresolved assumptions regarding the definitions of energy in the context of particle interactions, the implications of quantum mechanics versus classical mechanics, and the specific conditions under which annihilation is considered to occur.
thomas9459
More specifically, I am wondering what the energy released is when the electromagnetic force is also included in this calculation. In the case where the electron and positron are at a distance d, the energy released would be the mass energy (1.022 MeV) plus the energy that resulted from the electromagnetic attraction. Using Coulomb's Law, the energy released should be infinite, which is obviously not the case. What does QED say about the mater? Has an experiment which measured the energy released accurately enough to see the extra energy from the electromagnetic attraction?
That still doesn't answer the question of how much energy is released from the annihilation.
I'm a layman but I'd think that since the both particles are being annihilated, that no energy is released; don't they just cancel each other out?
That violates conservation of energy and is certainly not true at all.
Pal, you don't have to drag in QED in order to describe this phenomenon! This is perfectly describable using basic physics - the concept of conservation of energy (or rather, mass-energy in this case).
Imagine I have a system consisting of an electron and positron at a distance d from each other. The total energy of the system at that point is
[tex]m_{e}c^{2} + m_{p}c^{2} + KE_{e} + KE_{p} - k \frac{e^{2}}{d^{2}}[/tex]
By conservation of mass-energy, the total energy released when they annihilate is the same.
So a better question is at what distance do they annihilate. My impression was it happens when the electron and positron "touch", but since they are point particles, this would happen at d=0, which results in a division by zero.
you try to mix quantum mechanics with classical mechanics in not a good way and thus you result in this problem.
The phenomenon of annihilation is an electromagnetic one, thus you truly have electromagnetism already inside.
Generally it doesn't happen when they "touch". It happens in whatever a distance they are according to the possibilities of electromagnetism interaction (thus the coupling constant). Thus you have annihilation as you also have the pair creation of a photon of E_g ~> 1MeV (eg Na22)
  • · Replies 23 ·
  • · Replies 23 ·
  • · Replies 27 ·
  • · Replies 0 ·
