Comparing Volume of Oval vs Circle: Joe's First Post
  • Context: High School
  • Thread starter Thread starter turbojoe
    Circle Volume
The discussion centers on the volume change of a 4-inch round pipe when it is deformed into an oval shape. Participants confirm that the volume does change, particularly as the pipe approaches the limit case of being crushed flat, where the volume becomes zero. The complexity of accurately modeling the volume change is highlighted, with references to the isoperimetric inequality as a potential explanation for the observed phenomena. The conversation emphasizes the challenges in determining the exact volume at various stages of deformation.
  • Understanding of basic geometry and volume calculations
  • Familiarity with the concept of deformation in physical objects
  • Knowledge of the isoperimetric inequality in mathematics
  • Basic calculus, particularly integrals for volume measurement
  • Research the isoperimetric inequality and its applications in geometry
  • Learn about volume calculation techniques using integrals
  • Explore the effects of deformation on the physical properties of materials
  • Investigate modeling techniques for irregular shapes in engineering
Engineers, mathematicians, and physics enthusiasts interested in the effects of deformation on volume, as well as those involved in drag racing and related discussions on pipe design and performance.
turbojoe
This is my first post here and any help is appreciated. I belong to a drag racing forum and
this has been a hot topic of discussion.
If you have a 4 inch round pipe by 2 inches tall and insert the pipe into a vice and make it oval shaped it would somehow change the volume.
Please see video below.
http://www.youtube.com/watch?v=B24PtgujPOo&feature=youtu.be
thread from racing forum.
http://www.yellowbullet.com/forum/showthread.php?t=435379
I was under the assumption that the volume would not change. I suppose I'm wrong.
TIA,
Joe
The volume does change, this can be seen from the limit case that the pipe is crushed flat. If crushed flat enough, there is no volume left inside the pipe. However, to know how much the volume has changed at any instant before this limit case, well, that's a little more difficult. The crushing of the pipe distorts it irregularly and creates some kinks as well. It is very hard to model a situation like that exactly. To me, it seems hard to choose a best fitting ellipse to model the shape he has in the video. I'm not sure if you were looking for how to measure the volume directly (using integrals) or if you just wanted to know for sure if the volume does, in fact, decrease. Well it does (Technically the volume is infinite as the solid is not a closed one, one has to restrict the cylinder with two planes).
thanks for your response.. isoperimetric inequality seems to be the best explanation
42K
