Can Euler's Formula Be Modified to Create a Logarithmic Spiral?
  • Context: Graduate
  • Thread starter Thread starter Ahmidahn
    Change Formula
The discussion revolves around the potential modification of Euler's formula to create a logarithmic spiral. Participants explore mathematical transformations and implications of such modifications, including the calculation of arc lengths for related curves. The scope includes theoretical exploration and mathematical reasoning.
  • One participant questions whether a modification of Euler's formula, such as "e^-(i∅/n)", can mathematically represent a logarithmic spiral.
  • Another participant suggests changing the amplitude with angle and proposes that multiplying the y parameterization by the square-root of minus one could yield a complex representation of a logarithmic spiral.
  • A different participant proposes a transformation involving "cos θ + i sin θ" and expresses uncertainty about its relation to a logarithmic spiral.
  • One participant references circular polarization and expresses a desire to understand the mathematical transformations involved, indicating a need for further education.
  • Another participant suggests modifying Euler's formula to "e^{-a + iθ}" to achieve a logarithmic spiral and questions the nature of the variable "a".
  • There is a discussion about the dimensionality of the resulting curves, with some participants suggesting that the curves can be visualized in three dimensions depending on the parameters used.
  • One participant claims that replacing "i" in Euler's formula with "i - 1" results in a logarithmic spiral, presenting a specific parametric description.
  • Another participant defines a logarithmic spiral in polar coordinates and provides its parametric form, contributing to the mathematical framework of the discussion.
Participants express various viewpoints on how Euler's formula can be modified to represent a logarithmic spiral, with no consensus reached on the validity of specific transformations or definitions. Multiple competing views remain regarding the nature of the modifications and their implications.
Some participants express uncertainty about the definitions and implications of logarithmic spirals, and there are unresolved questions regarding the arc length calculations for the proposed curves. The discussion includes various assumptions about the parameters involved, which may affect the interpretations of the transformations.
Ahmidahn
Is there a way to take Euler's formula "e^(i∅)" -which gives a circle; and change it into a logarithmic spiral?
Does a simple modification like " e^-(i∅/n) " make any sense mathematically?
If it actually does, my other question would be; supposing that such a logarithmic spiral is in fact just a head on view of a space curve with parameters like:
y=tsint
x=tcost
z=e^(-t/12)
how does one go about finding the arc length of such a curve? I've attempted to use the general arc length formula on this one, but continually end up with something like:
s = ∫ √e^-t/12 + t^2 + 1
which is, apparently, impossible to solve.
Is there a way to use the complex variable in a formula like Euler's formula to create a logarithmic spiral? And if so, how does one go about calculating the arc length of such a thing?
Yeah - you change the amplitude with angle.
remember - euler's formula is for a circle in the complex plane.
the logarithmic spiral formula is for the real plane.
to change it to complex - just multiply the y parameterization by the square-root of minus one.
OR: you could just set Aexp(it) so that A=the radius of the spiral at angle t.
note: exp(it/n) just changes the frequency of the rotation.
Maybe something like:
(cos [itex]\theta[/itex] + i sin[itex]\theta[/itex])/w
would translate into:
[exp(i[itex]\theta[/itex])] / w where w is some decreasing function related to [itex]\theta[/itex]? I don't know. I've been stuck on this one for almost two years.
Thanks for your help.
The Wikipedia entry for "Circular Polarization" has the "classical sinusoidal plane wave solution of the electromagnetic wave equation" - and the math behind it as well.
It's similar, in general, to what I'm looking for. The math is beyond me. I actually know what some of those things are, but I think I would need to enroll in school again to understand usefully.
Tough stuff. Maybe I should ask some physics guys how to transform Circular Polarization into Spiral Polarization.
what if we take ei[itex]\Theta[/itex] and turn it into e-a+i[itex]\Theta[/itex]? Now we have a logrithmic spiral no?.
Yes. That would seem to make sense. Correct me if I'm wrong reinterpreting the equation.
e-a + i[itex]\theta[/itex] = (e-a)(ei[itex]\theta[/itex])=
(e-a)(cos[itex]\theta[/itex] + i sin[itex]\theta[/itex])
What kind of variable is "a" in this situation?
Is this a three dimensional curve, or rather, can it be visualized in 3 dimensions?
Thanks for your help there.
I'm going to have to suss that out for the arc length...hmm...getting closer.
a is an angle. Anything inside the exponential function must be dimensionless.
You can represent/visualize the curve how you like.
Taken as a locus of points in the complex plane, it is two dimensional.
If a is a constant, then the locus is a circle.
But you can also make the angle, any of them, a function of time - in which case, [itex]e^{i\theta(t)}[/itex] is rotating. You can make [itex]a[/itex] a function of time, or even of a third space dimension if you want ... and plot a locus in 3D or an evolving spiral path in 3+1.
Consider:
[tex]Ae^{\alpha t}e^{i\beta t} = Ae^{(\alpha+i\beta)t} = Ae^{zt}[/tex]
if [itex]\alpha=\beta=1[/itex], what is the shape mapped out in the complex plane?
You could also look at: [itex]at[\cos(bt)+i\sin(bt)][/itex], where a and b are arbitrary constants.
Have fun.
Replace [tex]i[/tex] in Euler's formula with [tex]i -1[/tex] and you get a logarithmic spiral:
[tex]e^{(i - 1)t}[/tex] parametrically describes a logarithmic spiral in the complex plane
In other words, in OP notation, a=-t \theta = t.
But you can have fun experimenting with lots of different spirals besides the golden one :)
Please define a "logarithmic spiral".
"Logarithmic spiral"= r = a(exp)-b(theta) in polar coordinates
Parametric form:
x(t) = r(t) \cos(t) = ae^{bt} \cos(t)\,
y(t) = r(t) \sin(t) = ae^{bt} \sin(t)\,
Are you wondering why I write the power in the exponent (theta) over "n"? Or what?
Thanks again for all the replies. I will be pondering this one for a while.
  • · Replies 16 ·
16K
