Are W and Z equal as random variables and do they have equal expected values?
The discussion revolves around the relationship between two random variables, W and Z, defined in terms of another random variable Y, which takes non-negative integer values. Participants explore whether W and Z can be considered equal as random variables and whether they have equal expected values.
  • One participant defines W and Z based on the values of Y and questions if they can be considered equal random variables, noting that W is undefined for certain values of Y.
  • Another participant challenges the notion of Y having a uniform distribution over non-negative integers and discusses the implications of defining probability distributions.
  • Some participants clarify that W and Z are functions of the same Y, but question the basis for claiming W equals Z, given their definitions.
  • It is noted that while W and Z may be equal almost surely (P[W=Z]=1), this does not imply they are equal as random variables in a strict sense.
  • Concerns are raised about the implications of defining Y in terms of various distributions and how that affects the equality of W and Z.
Participants express differing views on whether W and Z can be considered equal random variables, with some arguing they are almost surely equal while others emphasize the need for caution in making such claims. The discussion remains unresolved regarding the equality of expected values.
Participants highlight limitations in the definitions of Y and the implications for W and Z, particularly regarding the nature of probability distributions and the conditions under which W and Z may be considered equal.
kingwinner
Suppose the random varaible Y has non-zero probability at 0,1,2,3,... (i.e. the support of Y is the set of non-negative integers).
Define a random variable W:
W=0 ,if Y=0,1,2,or 3
--=Y-3 ,if Y=4,5,...
Define a random variable Z:
Z=max{0,Y-3}=0 ,if Y≦3
--------------=Y-3 ,if Y>3
And I have 2 questions...
1) Can I say that W and Z are equal as random variables (i.e. W=Z) ?
(what is bothering me is that W is undefined at e.g. Y=0.5, Y=2.2, etc. while Z is defined everywhere, my notes say that W and Z are equal random varaibles, but I just struggle to understand why)
2) Is it true that E(W)=E(Z) ?
Hopefully someone can clarify this! Thank you!
I'm having a little trouble following your specifications. For example, Y can't have a uniform distribution if its defined over all the non negative integers. Do you know why? If you have a binomial distribution, how do you define the mean (np) when n is infinite?
In general, probability distributions are defined by their mass functions (discrete) or density functions (continuous). Any given mass function or density function is defined by its parameters. For example, a Gaussian distribution can be completely defined by the values of its first two moments: the mean and the variance. Specifications of additional moments will define variations from the standard Gaussian (skewness, kurtosis). If random variables have the same distribution over the same range of values we say they are identically distributed. Because they are random variables, we don't say they are "equal" because, by definition, the values they take cannot be predicted precisely.
hmm...I don't think I said it's uniformly distributed.
Both W and Z are functions of the same Y.
W=g(Y)
Z=h(Y)
And I'm asking if we can say that W=Z.
Thanks!
W=g(Y)
Z=h(Y)
Thanks!
I don't know the source of your notes, but random variables by definition take unpredictable values according to a probability distribution. If two random variables have the same distribution, we say they are identically distributed. On what basis would they be equal?
You show W and Z as two different functions of Y. On what basis do you say W=Z even if they were not random variables?
You say Y is a random variable over the (infinite) set of the non negative integers. This implies a discrete distribution. It doesn't matter whether the distribution is uniform or not. I also showed how a binomial distribution would have to have an infinite mean if defined over the set of non negative integers.
Note that if you defined Y in terms of a uniform, binomial or Poisson distribution for some finite n or k, this last point would not be a problem. This would define a finite subset of the set of non negative integers.
W=g(Y)
Z=h(Y)
Thanks!
Yes there isn't enough information to say that W=Z, all we have is that P[W=Z]=1, i.e. W is almost surely equal to Z.
For a counterexample simply augment the event space \Omega with a point w such that P[{w}]=0 and set Y(w) and W(Y(w)) to whatever value you like.
OK. This means we are talking about P(W=Z) = 0 for continuous random variables. However, the fact that P=0 does not mean it is impossible. P(W = Z) converges to 0 over the real interval [0,1]. For discrete distributions, the value of P(W=Z) depends on the value of n (in the uniform and/or binomial case) which is why I made such a point of how the distribution of Y is defined. If you define both W and Z to be 0 (as the OP seems to have done for certain values of Y, although I have problems with how the OP defined this), then of course P(W=Z)=1 for those certain values of Y.
