Magnetic flux through a closed surface
The magnetic flux through a closed surface is always zero, as established by the Maxwell Equations, specifically Div(B) = 0. Even when considering a closed surface that encompasses one pole of a magnet, the magnetic field lines will cancel out, resulting in no net flux. This principle highlights the nature of magnetic fields, where field lines enter and exit both poles of a magnet, creating a symmetrical flow that does not distinguish between the North and South poles.
  • Understanding of Maxwell's Equations
  • Basic knowledge of magnetic fields and flux
  • Familiarity with the concept of magnetic poles
  • Concept of field line representation in electromagnetism
  • Study the implications of Div(B) = 0 in electromagnetic theory
  • Explore the properties of magnetic field lines in various configurations
  • Investigate the differences between electrostatics and magnetostatics
  • Learn about the applications of magnetic flux in real-world scenarios
Students of electromagnetism, physics educators, and anyone interested in the fundamental principles of magnetic fields and their behavior.
tomwilliam
This is always zero, right?
What if you construct a closed surface which only encompasses one of the poles of a magnet? Surely there would then be a non-zero flux as the inside of the surface would constitute a source (or sink) of magnetic field lines.
I'm new to electromagnetism, so any help appreciated.
Tom
Nope. What makes you think it would have a nonzero net flux? Just imagine what the setup looks like and you'll see that the flux will cancel.
Alternately just look at the Maxwell Equations (assuming that you believe in them of course). Div(B)=0.
Thanks. I had forgotten that the magnetic field lines can be thought of as passing through the inside of the magnet, so I take your point that they all cancel out.
That brings up a new question though: if the North pole of a magnet has field lines coming in and going out of it, and so does the South pole, then what exactly distinguishes them. As you can imagine, I've been approaching this as if it were electrostatics (hence not realising that the field lines pass through the centre) but it strikes me that there doesn't seem to be a difference between the two poles of the magnet...am I barking up the wrong tree?
  • · Replies 24 ·
