Question about capacitor voltage and inner dielectric effects?
This discussion centers on the behavior of capacitors connected to a high-voltage direct current (HVDC) power supply, specifically regarding dielectric polarization and breakdown. It is established that a capacitor's voltage cannot exceed the supply voltage, as excess electrons cannot generate additional voltage. The conversation highlights the Avalanche Effect, which may occur during dielectric breakdown, allowing for significant current flow and energy conversion. Furthermore, it suggests that dielectric breakdown could serve as a cost-effective alternative to Faraday electrolysis for hydrogen production, utilizing distilled water without salts.
  • Understanding of capacitor operation and dielectric materials
  • Knowledge of high-voltage direct current (HVDC) systems
  • Familiarity with the Avalanche Effect in electrical engineering
  • Basic principles of electrolysis and conductivity in water
  • Research the principles of dielectric breakdown in capacitors
  • Explore the Avalanche Effect and its implications in electrical circuits
  • Investigate the use of distilled water in electrolysis without electrolytes
  • Study the differences between Faraday electrolysis and dielectric breakdown methods
Electrical engineers, physicists, and researchers interested in capacitor technology, dielectric materials, and alternative methods for hydrogen production.
HMS-776
A capacitor is connected to a HVDC power supply which provides a minimal current.
When the volage reaches the capacitor plates the dielectric material in the capacitor polarizes.
Now, if there existed a barrier between the dielectric and the capacitor plate the capacitor could theoretically also operate like a transistor. If the voltage applied to the plates was high enough to break through the barrier free electrons will enter into the dielectric.
My question is, if this could occur would the excess electrons entering into the dielectric material cause the capacitors voltage to rise above the power supply voltage?
No, the capacitor voltage can only rise to the supply voltage. Where would any extra voltage come from?
If the dielectric breaks down, the voltage across the capacitor drops rapidly.
When the dielectric breaks down, the water conducts electricity. Conductivity allows current, so potential energy is converted into electron movement. There is a scientific effect known as Avalanche Effect which may occur in this situation, but I'm not sure. there may be temporary electron holes causing an avalanche, which again means lots of current, and potential energy is converted into movement of electricity rather than it's previous static built up state.
It is interesting that dielectric breakdown is not taught as an alternative to faraday electrolysis in schools. As far as I know dielectric breakdown means that no salts (electrolytes) are needed, so this would be a cheaper method of breaking down water, since salts cost money to add to a device, and salts clog up/dirty up the device with contaminants. Theoretically, distilled water could be used without any salts and still produce hydrogen, since distilled water does conduct electricity without any salts at a dielectric break down. WIthout the dielectric breakdown, water is not a good conductor. Faraday did not have this knowledge back in the day when he was doing his tests.
  • · Replies 30 ·
