Difference between Entailment and Implicaiton
  • Context: Graduate
  • Thread starter Thread starter friend
    Difference
The discussion revolves around the logical concepts of entailment and implication, exploring their definitions, relationships, and distinctions. Participants examine the nature of these concepts within the context of propositional logic, including their mathematical representations and interpretations.
  • One participant describes implication as a relationship between two propositions, noting that it is valid except when a true premise leads to a false conclusion.
  • The same participant expresses uncertainty about entailment, suggesting it occurs when a conjunction of statements is not inconsistent with another statement, and questions whether this implies a direct relationship between the two.
  • Another participant clarifies that implication is a logical connective, while entailment is a relationship between formulas, emphasizing that they are distinct concepts.
  • This participant introduces the deduction theorem, stating a formal relationship between entailment and implication.
  • A subsequent post seeks clarification on the notation used in the deduction theorem, questioning the correct formulation.
  • Another participant confirms the intended formulation of the deduction theorem, while critiquing the alternative as nonsensical.
Participants express differing views on the relationship between entailment and implication, with some suggesting they can correspond while others emphasize their distinct nature. The discussion remains unresolved regarding specific cases where entailment does not imply a direct implication.
Participants rely on formal definitions and mathematical representations, which may depend on specific interpretations of logical connectives and relationships. There is an ongoing exploration of how these concepts interact within propositional logic.
friend
What's the difference between the logical concepts of entailment and implicaiton? I know what implication is between two propositions; every case is allowed except a true premise and a false conclusion. But I'm not quite sure what entailment is.
As I understand it, entailment occurs when a conjunction of statements is not inconsistent with another statement. But doesn't this also mean that the conjunction of statements implies the other? Can anyone give me a case when the relationship is entailment but not implicaiton? Any clarification would be appreciated. Thank you.
They can correspond. That is, if P entails Q, P may also be said to imply Q. However the first is statement based on a proof that P necessarily entails Q. The second is simply based on truth tables. So if P is true and Q is true, then P implies Q under both strict and material implication. However the two statements don't necessarily have anything to do with each other.
For example, P (S is a man) and Q (S likes ice cream). If both statements are true, we can say the P implies Q, but P doesn't necessarily entail Q. For that, you would need a third statement, that all men like ice cream.
EDIT: I can't think of a case where P entails Q would not also indicate P implies Q under material implication.
Implication ([itex]\rightarrow[/itex]) is a logical connective, just like [itex]\wedge[/itex] or [itex]\vee[/itex]. Entailment ([itex]\vDash[/itex]) is a relationship between formulas.
[itex]\varphi \rightarrow \psi[/itex] is a formula, a mathematical object. It makes no more sense to assert that [itex]\varphi \rightarrow \psi[/itex] than it makes to assert 2 or [itex]\mathbb{R}[/itex]. [itex]\Gamma \vDash \varphi[/itex] is a mathematical statement about the relationship between the set of formulas [itex]\Gamma[/itex] and the formula [itex]\varphi[/itex], which may be true or false. In the context of classical propositional logic, it says that [itex]\varphi[/itex] is true in every interpretation in which each formula of [itex]\Gamma[/itex] is true.
The two are related by the deduction theorem: [itex]\Gamma, \varphi \vDash \psi[/itex] iff [itex]\Gamma \vDash \varphi \rightarrow \psi[/itex].
Did you mean: [itex]\Gamma, \varphi \vDash \psi[/itex] iff [itex]\Gamma \vDash (\varphi \rightarrow \psi)[/itex]
Or did you mean: [itex]\Gamma, \varphi \vDash \psi[/itex] iff [itex](\Gamma \vDash \varphi )\rightarrow \psi[/itex]
The former. The latter makes no more sense than [itex](2 < 3) \times 2[/itex] (as opposed to [itex]2 < 3 \times 2[/itex]). Implication connects formulas, [itex]\Gamma \vDash \varphi[/itex] is not a formula.
  • · Replies 43 ·
13K
  • · Replies 64 ·
