Sinc Function in Natural Phenomena
  • Thread starter Thread starter Bassalisk
    Function Nature
The discussion centers around the characteristics and applications of the sinc function, particularly in relation to natural phenomena and its mathematical properties. Participants explore examples where the sinc function may describe or approximate behaviors in nature, with a focus on diffraction and the Fourier transform.
  • One participant expresses a personal affinity for the sinc function and seeks examples of its occurrence in natural processes.
  • Another participant suggests that light diffraction through a slit exhibits characteristics of the sinc function, noting that the amplitude is related to the sinc function squared.
  • A subsequent reply reinforces the idea of the slit acting as a lowpass filter, likening the light to an impulse.
  • Further clarification is provided regarding the calculation of intensity in diffraction, involving the summation of contributions from points on the slit and the use of sine functions to describe phase variations.
  • One participant elaborates on the relationship between slit patterns and Fourier transforms, mentioning the potential for using laser light to visualize these transforms.
  • Another participant expresses interest in researching the topic further, indicating the discussion has prompted new considerations.
While there is some agreement on the relationship between the sinc function and light diffraction, participants express differing views on the descriptions and implications of these phenomena. The discussion remains unresolved regarding the precise characterization of these relationships.
Participants reference mathematical concepts such as Fourier transforms and the behavior of light through slits, but there are unresolved assumptions regarding the definitions and applications of these concepts in the context of the sinc function.
Bassalisk
Its my favourite function.
[itex]\Large{\frac{sin(x)}{x}}[/itex]
I first saw it 1 year ago, when we studied limits. I don't know why, but I really like this function.
Can anybody tell me an example, in nature where we have behaviour that has sinc function characteristics.
Why am I asking this?
Fourier transform of aperiodic square wave is this function(give or take few constants).
And this function would be impulse response of lowpass filter.
So a natural process, that can be described with sinc function. Or approximated with it.
Hmm, off top of the head if you shine light through a slit it should diffract like sinc function (the amplitude being sinc function squared) for exact same reason why Fourier transform of aperiodic square is sinc.
Yes yes! How could have I missed that?! The slit experiment. So the slit would be a lowpass filter here, and my light would be a impulse?
Sort of, though I wouldn't describe it this way.
The intensity is given as integral of the phase from the slit to the screen over the slit width. When you are calculating intensity of the light in direction a (in radians off the centre) you're summing the contributions from every point on the slit multiplied by sines of their phases. The factor varies over the slit as sin(x*sin(a)*2pi/wavelength) (edit: better way to put it is to use complex numbers and e^(i*x*sin(a)*2pi/wavelength) for the multiplier). For a slit that is big relatively to wavelength, the relevant a is small and sin(a)~=a . The summing is same as in Fourier transform, essentially.
You can have some pattern of slits, and then shine laser light through and on the screen see Fourier transform* of that slit pattern (provided that the screen is far enough away). Isn't that cool. Doing the Fourier transform with laser.
*the amplitudes, if you want phase you'll need a beam-splitter to add the beam here so that you can see just the imaginary or just the real part. That's actually the principle behind holography. A hologram is sort of frequency-domain image of the object (not exactly so though).
The intensity is given as integral of the phase from the slit to the screen over the slit width. When you are calculating intensity of the light in direction a (in radians off the centre) you're summing the contributions from every point on the slit multiplied by their phases. The phase varies over the slit as sin(x*sin(a)*2pi/wavelength). For a slit that is big relatively to wavelength, the relevant a is small and sin(a)~=a . The summing is same as in Fourier transform, essentially.
You can have some pattern of slits, and then shine laser light through and on the screen see Fourier transform of that slit pattern (provided that the screen is far enough away). Isn't that cool. Doing the Fourier transform with laser.
Interesting. I will research this through. Thanks! Gave me a lot to think about.
9K
  • · Replies 20 ·
  • · Replies 53 ·
