Understanding and Connecting CO2 Canisters to Piping for Scientists
  • Thread starter Thread starter The Engineer
    Building Launcher
This discussion focuses on the proper connection of CO2 canisters to piping systems, specifically for applications such as model airplane engines. Users clarified that a filler tool is essential for puncturing the CO2 cartridge, allowing gas to flow into the connected tank. The typical duration of operation for these systems is approximately 20-30 seconds. Additionally, the pressure of 8g and 12g CO2 canisters varies based on the container's volume, but specific psi values were not provided in the discussion.
  • Understanding of CO2 canister types and specifications
  • Familiarity with gas pressure concepts
  • Knowledge of piping systems and connections
  • Experience with filler tools for gas cartridges
  • Research the specifications of 8g and 12g CO2 canisters
  • Learn about the operation and maintenance of model airplane engines
  • Study the use and safety of gas filler tools
  • Explore the effects of gas pressure in different container volumes
This discussion is beneficial for engineers, hobbyists working with model airplanes, and anyone involved in the handling and application of CO2 canisters in scientific or recreational settings.
The Engineer
I'm having problems trying to figure out how CO2 canisters work. I've never actually used them before so how would you connect a CO2 canister to a piece of piping. What I have trouble understanding is how you would open the CO2 cartridge and connect it to the pipe. Would it be by puncturing the canister after the connection has been made (somehow) or do you open the canister beforehand and then quickly insert it to the pipe?
Also I how much psi would there be if I had an 8g or 12g CO2 canister? I know it depends on the volume of the container, but whenever I try to look at the specifications of the item, I can't find pressure.
Thanks!
the engineer
CO2 model airplane engines carry a TANK connected by
pipe to the engine
they use a filler tool that punctures the CO2 cartridge
and fills tank
good for running 20-30 seconds
happy holidays!
  • · Replies 31 ·
  • · Replies 31 ·
23K
  • · Replies 27 ·
  • · Replies 0 ·
