H-pattern to sequential shifter
  • Thread starter Thread starter meLokesh
The discussion revolves around the conversion of an H-pattern gear shifter from a Maruti Suzuki-800 into a purely mechanical sequential shifting system. Participants explore design ideas and mechanical mechanisms to achieve this without the use of electronics, focusing on the challenges and feasibility of such a conversion.
  • One participant proposes using four linear hydraulic actuators to control the gear-stick motion in two perpendicular directions but struggles with mechanical control mechanisms.
  • Another participant emphasizes the fundamental differences between manual and sequential gearboxes, suggesting that a direct conversion may not be feasible without significant design changes.
  • Some participants suggest using a barrel cam mechanism similar to motorcycle shifters to achieve the desired shifting action.
  • Concerns are raised about the complexity and weight of adding a mechanical system to the existing manual gearbox, questioning the practicality of the project.
  • A participant mentions the need for a ratcheting mechanism and seeks clarification on how to integrate two profiles on a single cam for the shifting action.
  • Several links to external resources are shared for reference, including examples of existing shifter designs.
Participants express differing views on the feasibility and practicality of converting a manual gearbox to a sequential system. While some suggest potential mechanical solutions, others argue against the viability of the project, indicating a lack of consensus on the approach.
Participants note the limitations imposed by competition rules, which restrict modifications to the gearbox itself, thus influencing the design constraints for the proposed mechanical system.
This discussion may be of interest to automotive engineering students, hobbyists working on vehicle modifications, and those exploring mechanical design solutions for shifting mechanisms.
meLokesh
Hi everyone, :smile:
I am working on a project that involves converting H-pattern gear shifter(like any road car with manual gearbox) of Maruti Suzuki-800 into a sequential shifting system. I came up with a design that uses 4 linear hydraulic actuators to provide motion to the gear-stick in 2 perpendicular directions in a plane, thus, achieving the gear shifting. But now the problem is I can't use electronics to control the open/close sequence of the actuators, I only can control them mechanically. I can't think of any such mechanical mechanism to control them, please suggest some mechanism.
You can also suggest an entirely different system for sequential shifting, but that should be purely mechanical.
Waiting for advices...:rolleyes:
http://www.ikeya-f.co.jp/en/product_notice/sequen_shifter.html
Ya I can use their stuff but the thing is that all the professional sequential shifter makers use electronics in their shifters & the rules don't allow me to use any FLY BY WIRE. :cry: And if I'm not wrong most of these are for transmissions with 3 shifter rods but mine on the contrary has just one rod( which needs to be given in/out & rotary motion) as you can see in my previous post. Perhaps that's why I was thinking of making one rather than purchasing. But I don't have enough experience & knowledge to do it & need some guidance to design a completely MECHANICAL mechanism...NO electronics!
Manual gearboxes and sequential gearboxes work in very different ways. You can't simply make a manual into a sequential without fundamental changes to the design. The gears are actuated very differently in the gearbox. (eg Three separate rods and forks vs a barrel cam.)
What you are suggesting in the OP is a fully mechanical robot that bolts on to the gear stick and does a manual gear change for you. From a driving aspect seems a total waste of time, money and effort. As you are increasing weight and complexity for no reduction in shift time, the lack of ability to skip damaged gears and you still have to manually control the clutch yourself.
Basically lots of cons and no pros at all.
It'd be much easier to fit a bike engine and gearbox, thus getting you a sequential shift (and probably more power than an old Suzuki Alto)Why are you trying to do this?
Ever seen Lenco trannies in action?
http://www.bangshift.com/blog/Gear-Bangin-Video-Steve-Clukey-Pulls-Levers-and-Adjusts-the-Rear-View-At-140mph.html
Ya it's bit difficult but I'm trying if anything can be done...someone told that it might be done with some ratcheting cams or drum..
I am doing this for my car participating in SUPRA FSAE 2012...the rules forbid me to even look at the gearbox, leave alone making some changes in it & you are talking about changing the entire gearbox :eek:. I have to use the provided powertrain(with manual gearbox) of Maruti 800 as it is.
Here's the shift pattern..
http://www.acmejeepparts.com/Assets/Images/15445/15445-md.jpg
& this is the shifter assembly..
http://tis.spaghetticoder.org/images/1/02/24/56.jpg
1=Shift arm 6=Support bearing (shift arm bearing)
7=Shift lever
2=Ball socket (shift lever bearing) 8=Shift rod
3=Shift lever cover (gaiter) 9=Shift rod joint
4=Shift lever knob 10=Bearing bush
5=U-gaiter
It has just one single rod instead of 3, so perhaps it might simplify the things..
Then you'll have to come up with a mechanism that operates in two planes to "stir" the shifter to get a H-pattern shifting action from a single plane (fore and aft) motion.
Easiest way might be to use somewhat the same principle that a motorcycle shifter uses (barrel cam). Cut a zig-zag groove (\/\/) in the barrel cam to operate the fore and aft action and another groove that steps to the side to move between the 1-2 and 3-4 gates. Use a ratchet to move the barrel cam. Maybe use a separate lever to operate reverse.
maybe this is the kind of profile i'll be needing...
http://img56.imageshack.us/img56/9871/seqextconversion8dg.jpg
of course its for a 6-speed gearbox & mine is 5-speed...i mistakenly said before that it was 4-speed :-p...but still the pattern is same..
http://t1.gstatic.com/images?q=tbn:ANd9GcRf1GkZGkPg19yqZefrxcWtxabawqAyozHrH3PIOol_zIC5vqR0jhH5NLnixQ
however, I can't understand the ratcheting part...& if we go like 1/2/3/4/5 shifts..how to move in opposite direction..like 5/4/3/2/1 ? is somehow the ratchet going to reverse or what..:confused::confused::confused:
mender said:
Yep, that's the profile. For the ratcheting mechanism, copy one from a motorcycle. Read this:
http://www.dansmc.com/gearshifters.htm
hey now I understood the ratcheting concept..the one like in bike gearboxes..but the last thing remaining in the design which I can't get is the one i stated in my previous post...HOW TO GET THE 2 PROFILES(RED & BLUE)..in graph from my previous post..ON THE SAME CAM TOGETHER & HOW THE 2 FOLLOWERS WILL BE CONNECTED TO THE SHIFTER ROD :confused::confused:..please just explain(if possible)with a drawing how can it be done...
its the last thing to be done in the design..so can't wait.. :bugeye:
To get both profiles on one cam all you do is take your graph of the two profiles and roll it into a cylinder. Several of the mechanisms in that last link have exactly that; have another look at this one:
http://www.dansmc.com/suzy_re5_shifter.gif
Part #4 is the barrel cam and shows three grooves on the same barrel; you only need two grooves.
To get left and right motion (the red stepwise profile) you just need a lever that connects the groove in the cam on one end and the shifter on the other. The fore and aft (the blue zig-zag profile) isn't much different but would have a 90 degree bellcrank instead of a straight lever; that changes the direction of motion - and that's how you output two planes of motion from a single plane input.
http://www.google.ca/imgres?imgurl=...8AT7COE6nv0gHr7JiBAg&ved=0CC0Q9QEwAQ&dur=1207
the left-right movement going to be easy, but although the bell crank would do the job for fore-aft movement...don't you think for every fore/aft movement..the lever(used for connecting the shifter & the cam for left-right motion) will also move fore/aft as its connected to the fore/aft moving shifter...& will part from the cam..how to deal with that?? splined hollow rod like in propeller shaft or something more easy & practical you suggest here...
any ideas about how to calculate the radiator size needed for the cooling...mine is MARUTI 800---796cc, 37bhp @ 5000rpm, 3 cylinder petrol engine...
i was thinking of installing 2 radiators on either sides of the car..
Why do you want 2 radiators? One tiny, one will cool that thing.
Pumping the extra water through the added plumbing will sap 99.9% of the total power of the engine.
You could open the bonnet and blow on the block and it'd be sufficient cooling.
In all seriousness, why not just look at the existing size of the radiator and look at it's rated cooling capacity.
A lesson needs to be learned here as this is engineering.
It's sort of the golden rule. Keep it as simple as you possibly can.
xxChrisxx said:
Why do you want 2 radiators? One tiny, tiny, tiny one will cool that thing.
funny! :biggrin::biggrin:
would it be enough if i use 2 bike radiators??...maybe honda cbr250r's...or any bike u suggest..:rolleyes:
one more thing...if i install 2 radiators on both sides...would it be better to have pumping in both the radiators in parallel or series configuration??
Radiators work most efficiently when there is a large temperature differential between the coolant in the tubes and the air passing through the fins. If you go with series configuration, the first radiator will be the most efficient, and the second will be much less so. I haven't crunched any numbers, but intuitively, running them in parallel should put both of them to the best use.
I'm not so sure about that, in theory yes, in practice testing is the only way to really know.
I remember Mike had a single seater that had 2 radiators. We had a similar discussion back then, in the end I think they were plumbed in in series. flushed system with, deionised water and water wetter probabl make the biggest difference though.
edit, found it:
https://www.physicsforums.com/showthread.php?t=3635022 radiators are still majorly overkill for an 800cc engine that's putting out less power than a twisted rubber band. Overcooling is just as band as undercooling.
someone please solve this problem too..both the followers being attached to the same shift lever going to move left/right or fore/aft accordingly with the other follower...how to deal with that?:confused:
You could use a slot type arrangement that allows free movement in the other plane without losing the control in the desired plane. The splined shaft you mentioned would work as would a few other methods.
hey, did you do any further work on the sequential shifter??
Yes I did, but only designed the cam profiles as the whole idea was scraped due to complexity in functioning & undue expenditures involved with not so improved operational ease & efficiency.
What are you working on?
even i encountered the complexities in the cam functioning so wanted to ask u if u had done anything about it.
eventually i too had to scrap that idea bcoz of the complexities. I replaced the cams with servo's.
pneumatic actuators would be best for the job, you would need only 2 of them...they will eliminate the shift-stick entirely & would be fast and easy for the driver.
yup...it would be easy but i can control servo's with programming...i will be needing an altogether different mechanism to control the pneumatic drives...
Good...don't forget to share your finished design & product.
I will...;D
hz1363 said:
I will...;D
Hi
Mechanical sequential shifters are mad
Peter Munro said:
Hi
Mechanical sequential shifters are made by http://www.sqsracing.com/
They use a disc.
Why didn't they just make sequential shifting from the beginning?
Peter
10K
  • · Replies 19 ·
9K
