Paramatrize a peicewise function?
  • Context: Undergrad
  • Thread starter Thread starter 600burger
    Function
The discussion revolves around the parametrization of piecewise functions, specifically focusing on linear segments and circular arcs in both 2D and 3D spaces. Participants explore methods to derive parametric equations for these functions and address challenges encountered in the process.
  • Homework-related
  • One participant seeks a formulaic approach to parametrize a piecewise function, starting with a linear segment from (1,3) to (0,0).
  • Another participant suggests using the slope-intercept form of a line and proposes a method to express points on the line segment in terms of a parameter ranging from 0 to 1.
  • A later reply indicates that the participant successfully recognized the need for a parametrization of a circular arc in 3D space defined by the equation y² + z² = 1.
  • Participants discuss the challenges of parametrizing non-linear segments and the potential to reduce the problem to a 2D case.
  • One participant arrives at a solution for y(t) and z(t) using trigonometric functions, indicating a realization of the geometric nature of the problem.
  • There is a discussion about the correct range for the parameter t in relation to the piecewise function, with emphasis on maintaining clarity in the parametrization process.
  • Another participant confirms that the proposed parametrization is valid if it correctly represents the circular arc and starts and ends at the appropriate points.
Participants generally agree on the methods for parametrizing linear and circular segments, but there are varying approaches and some uncertainty regarding the correct parameter ranges and the handling of piecewise transitions.
Participants express challenges with non-linear systems and the lack of examples in their reference materials, which may limit their understanding of the parametrization in 3D space.
Students and educators in mathematics or physics who are dealing with piecewise functions, parametrization techniques, or preparing for exams involving these concepts.
600burger
Can someone hepl me find a "formual" way to paramatrize a peicewise function? Up till now I've been doing it with guess and check and am now stuck on the last part.
The line goes from (1,3) to (0,0)
So far I have
[itex] 7 \leq t \leq 10[/itex]
[itex] y(t) = 10 - t[/itex]
and am stuck on find a function for [itex]x(t)[/itex]
Thanks.
One way is to find an ordinary expression for the line, something of the form y = mx+b, then use your known expression for y to get an expression for x.
However, a more common way to parametrize lines is to identify each point in terms of the "proportion" from the first to the last point.
That is, you put your variable in the range [0, 1], then the corresponding point on the line segment AB is given by:
P = (1 - t) A + t B
Brilliant!
I don't know why that eluded me...
-Burg
So now in 3-Space,
The line goes from (0,1,0) to (0,0,1) on the function [itex]y^2+z^2 = 1[/itex]
i have [itex]x(t) = 0[/itex] which is obvious, but how do i find the other two, [itex]y(t)[/itex] and [itex]z(t)[/itex]
i can't sovle a system like i did with the last one, and since its not linear, I am not sure if that second method works either. Unfourtunetlly my book is lacking in 3-space examples...
-Thanks!
Can you reduce it to a 2-space problem?
I could "pretend". But since both y and z are changing I'm have trouble seeing what one would be to sub in for the other. Any hints on where to start?
-Burg
You should already be familiar with a parametrization of an equation of the form [itex]p^2 + q^2 = 1[/itex]... do you recognize the geometric object it defines?
I just got it, after i posted that last one. It's a circile (duh, brain fart) so i use y(t)= cos t and z(t) = sin t. But there was a piece right before it, so [itex]3 \leq t \leq[/itex]? So does that mean
[itex]y(t) = cos ((t-3)\frac{\pi}{2} )[/itex]
[itex]z(t) = sin ((t-3)\frac{\pi}{2} )[/itex]
[itex]3 \leq t \leq 4[/itex]?
If that parametrization lies on the circular arc, and begins and ends in the right place, then it's good!
I'm not sure what you mean by "a piece right before it" -- I guess you're talking about another part of the problem you've already solved.
Ya, there was another piece of the piecewise goes from (3,0,0) so [itex]0 \leq t \leq 3[/itex] then the next piece (this one) starts at 3. I guess i could just start at 0 for each one, but this is how our prof tought it, and probablly how he wants to see it done.
Thanks for the help! Final's on monday!
The way you did it is right -- you wouldn't have a very well defined parametrization if it takes t=0 to two different points!
  • · Replies 23 ·
