Confusion over Newton's 3rd law
  • Context: High School
  • Thread starter Thread starter johnathon
    Confusion Law
The discussion revolves around the interpretation and implications of Newton's third law of motion, particularly in scenarios involving forces and motion. Participants explore various examples, including a car's exhaust, pushing a box, and the interaction between a person and the ground. The scope includes conceptual clarifications and technical reasoning related to forces and acceleration.
  • Some participants question how Newton's third law can coexist with acceleration, suggesting that equal and opposite forces should result in equilibrium.
  • Others clarify that action and reaction forces act on different objects, which allows for acceleration despite the equal forces.
  • A participant proposes a scenario of pushing a box and discusses the implications of forces acting on themselves and the box.
  • Some participants emphasize that the net force on an object is determined by all forces acting on it, not just the action-reaction pairs.
  • There is a discussion about the role of the ground in exerting forces and how it relates to movement and acceleration.
  • Participants explore the idea of gravitational forces between a person and the Earth, noting that both exert equal and opposite forces on each other.
  • There is a clarification that the upward force from the floor is not a reaction to gravity but rather a separate interaction.
Participants express differing views on the implications of Newton's third law, particularly regarding equilibrium and net forces. While some points are clarified, the discussion remains unresolved on certain aspects, particularly the relationship between action-reaction pairs and net forces.
Some participants highlight the importance of distinguishing between forces acting on different objects and the conditions under which forces can be considered balanced or unbalanced. The discussion includes assumptions about ideal conditions, such as the absence of friction and air resistance.
This discussion may be useful for students and enthusiasts of physics seeking to understand the nuances of Newton's third law and its applications in various physical scenarios.
johnathon
If there is always an equal an opposite reaction, wouldn't everything always be in equilibrium and there'd be no net forces? If a car's exhaust is pushing back with xN, the car gets pushed forwards with xN. So the net force is 0 so how can there be acceleration?
Newton's third law says that if object X exerts a force F on object Y, then object Y must necessarily exert a force -F on object X. Two objects, two forces (which are equal but opposite).
The force that object X exerts on object Y has nothing to do (directly) with the motion of object X. All that matters with respect to the motion of object X is the force exerted by object Y on object X, and by object Z, and every other object that exerts a force on object X.
No. Realize that the 'action' and 'reaction' forces act on different objects.
Look at the exhaust and the car (rocket?) as separate systems. There's a force (from the exhaust) on the rocket, so the rocket accelerates; there's a force (from the rocket) on the exhaust, so it accelerates. (Ignoring other forces, of course. And I assume you are thinking of a rocket and its exhaust, not a car.)
Sure, if you treat the 'rocket + exhaust' as a single system there's no net force, then the center of mass of the system does not accelerate. But each subsystem certainly does.
Ok. But what about if I push a box forward and it moves across the floor (with no air resistance or friction)? How would you approach that with Newton's 3rd law?
The box would push you backward (Newton's 3rd law) and you would move across the floor in the opposite direction (Newton's 2nd law with no air resistance or friction).
You push the box (to the right, say) and the box pushes back on you with an equal force (to the left). That's what Newton's 3rd law says.
Of course there must be other forces acting on you, otherwise you wouldn't get very far. Presumably the floor is able to exert a force on you so you can accelerate to the right and maintain the force on the box.
If there really were no friction at all, you'd push the box (and the box would push back on you) and you'd both accelerate in opposite directions. (Until you broke contact, after which you'll continue to move at constant speed in opposite directions.)
DaleSpam said:
The box would push you backward and you would move across the floor in the opposite direction (with no air resistance or friction).
So because my mass is much greater than the mass of the box I'll accelerate much less?
But wouldn't me pushing back on the floor and the floor pushing on me balance out so nothing would change?
No. Sure, if you only push back on the ground with a force exactly equal (and opposite) to the force you exert on the box, then the net force on you would be zero and you wouldn't accelerate. But that's got nothing to do with Newton's 3rd law. There's no reason why you couldn't push back on the ground with a force greater than you exert on the box.
Newton's 3rd law says, regardless of anything else:
Whatever force you exert on the ground will be equal and opposite to the force exerted by the ground on you.
Whatever force you exert on the box will be equal and opposite to the force exerted by the box on you.
So just with the example of walking forward, I push back on the ground with my foot and the ground pushes equally back on me? Because the Earth is so massive it's movement away is insignificant and my movement forward is a lot more noticeable? Is that correct? But then surely it's still a state of equilibrium. So how can the idea of a net force ever exist?
That's true.
The ground is exerting an unbalanced force on you, so you accelerate forward. That's not equilibrium.
Net force on what?
But doesn't my force backwards on the ground balance it out?
How can a force on the ground balance out a force on you?
For forces to 'balance out' they must act on the same object.
Ah, thanks. I finally get it. So does that mean if I'm falling on Earth (disregarding air resistance) the Earth is pulling me down so I'm pulling back on the earth? If I jump up the Earth moves back in response?
Yes, you and the Earth exert equal and opposite gravitational forces on each other.
Sure. When you shove off against the earth, you exert equal and opposite forces on each other. Of course, the Earth is massive compared to you and barely moves.
And if I'm standing on the floor and not moving, would there be two action reaction pairs? The Earth pulling on me and me pulling the earth. The floor pushing up on me to stop me falling and me pushing down on the floor? So the floor pushing me up isn't the reaction to gravity?
Exactly!
Right! That's one of the most common errors, to think that the floor pushing up is a Newton's 3rd law 'reaction' to gravity. You've got it right.
Doc Al said:
Exactly!
Out of me pushing on the floor and the floor pushing up on me, which is the reaction? An I pushing down on the floor because the Earth is pulling me down? So the upwards force of the floor is responding to that? So the floor pushing up is a response to me being pulled by gravity, but it isn't the reaction force in terms of action reaction pairs?
The terms 'action' and 'reaction' are somewhat old fashioned and misleading. It makes it sound like one force is the 'action' and the other is the 'reaction', but those distinctions are arbitrary. It's better just to refer to those forces as Newton's 3rd law pairs.
Sounds good to me. If there were no gravity, then there would be no need for the floor to push you up. But they are not Newton's 3rd law pairs.
A good example to illustrate why the force exerted by the floor on you need not necessarily equal your weight is to think of you standing on a scale while in an elevator. As long as the elevator is not accelerating, then the scale pushes up on you with a force equal to your weight. But if the elevator accelerates upward, then the force exerted by the scale must be greater than your weight. So obviously those forces are not 3rd law pairs.
So if the elevator is Pushing up on me more than gravity pulls down, would I feel heavier because I have to push down with more to match the force from the elevator?
Yes. You don't 'feel' gravity directly, what you feel is the force supporting you. So if you're being accelerated upwards, you'll feel heavier. And if you fell out of a window, you'd feel weightless (until you hit the ground).
Would an object not actually in contact with the elevator but still in it feel this force? So if I were to throw a ball upwards in an elevator accelerating upwards, would the ball still accelerate with the elevator?
Nope.
Nope. As soon as it left your hand, the only force acting on it would be gravity.
Doc Al said:
Nope.
I know I'm getting very off topic on the elevator idea but I promise these are my last two questions :-)
If an elevator was in freefall what would happen?
And if an elevator is accelerating downwards faster than gravity would I stay "stuck" to the ceiling?
You would feel 'weightless' and just float in the elevator. There would be no force between you and the elevator, since you'd both be in freefall.
Yes. Once you were in contact with the ceiling, you'd stay there. You could stand upside down, if you wanted.
I don't get why I'd feel weightless. How would you explain that in terms of forces?
The only force acting on you would be gravity. Without a support force, you'd feel 'weightless'. I put that in quotes since you obviously still have weight, you just don't feel it.
Why wouldn't you feel gravity? There's still a force acting on you
Yes, there's a force acting on you, but since it acts on every tiny bit of you uniformly you can't feel it. What you can feel are the stresses and tensions created in your body when your weight is support by something. Stand on the floor and the upward force creates tensions in the body that you can feel. If the floor suddenly gave way, those tensions would disappear, which we interpret as a 'weightless' feeling. The same feeling that astronauts in the space shuttle have.
I assume you've been in a roller coaster? Or a car going over a large bump? Or even an elevator accelerating downward. In those situations your feeling of weight decreases for a bit. If you were to drive off a cliff, you'll experience that weightless feeling for a bit longer. (Not advisable, of course.)
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 40 ·
  • · Replies 62 ·
  • · Replies 18 ·
  • · Replies 58 ·
9K
