Proving Limit Laws - Pauls Online Math Notes
  • Thread starter Thread starter Alfredoz
    Laws Limit Proof
The discussion revolves around proving limit laws as outlined in Pauls Online Math Notes, specifically focusing on the relationship between ε and δ in the context of limits. Participants are exploring the implications of various ε values, such as |L|/2, and how these relate to the limit of a function g(x) as x approaches a.
  • Participants are attempting to understand the derivation of inequalities involving |g(x) - L| and how specific ε values influence the proof. Questions are raised about the choice of |L|/2 and its role in establishing bounds for δ.
There is an ongoing exploration of the relationships between ε and δ, with some participants providing insights into how to manipulate these expressions. While no consensus has been reached, the dialogue reflects a productive examination of the concepts involved in limit proofs.
Participants are navigating the constraints of the problem as outlined in the homework context, questioning the assumptions made in the proofs and the definitions of ε and δ. The discussion highlights the need for clarity in understanding the implications of chosen values in limit proofs.
Alfredoz
Dear All,
I need help on proving:
According to Pauls Online Notes,
we let ε > 0. Since [PLAIN]http://tutorial.math.lamar.edu/Classes/CalcI/LimitProofs_files/eq0075M.gif, there's a http://tutorial.math.lamar.edu/Classes/CalcI/LimitProofs_files/eq0076M.gif such that
I understand that l g(x) - L l < ε, but how do we derive l g(x) - L l < l L l / 2 ?
Alfredoz said:
Dear All,
What does it mean (in terms of δ and ε) for [itex]\displaystyle\lim_{x\,\to\,a}\ g(x)=L\ ?[/itex]
In particular, if you let ε = |L|/2, then you know that there is some number, call it δ1, such that whenever 0 < | x - a | < δ1,
then | g(x) - L | < |L|/2 .
Hi SammyS, thanks for reply. But how do you get | L |/2 ?
Often, the way you come up with such quantities is to "play around" with the δ and the ε expressions, (often working backwards, so to speak, that is -- from the ε to the δ) to find a relationship between δ and ε.
So, off hand, I don't know why he chose |L|/2 , but I haven't gone through his whole argument.
It's just that he's using the |L|/2 for ε, so we know δ1 exists from the definition of the limit and knowing that [itex]\displaystyle\lim_{x\,\to\,a}\,g(x)=L\,.[/itex]
Hi, please refer to:
http://tutorial.math.lamar.edu/Classes/CalcI/LimitProofs.aspx( Proof of 4)
Yes, after looking at this (I had already found it.), maybe I should ask you "What is the role of |L|/2 in the proof?"
BTW, there is nothing magic about |L|/2 itself. All that's needed is something less than |L|.
He uses |L|/2 to get δ1. He uses δ1 to get a bound on 1/|g(x)| , because when you consider what needs to be proved, you realize that you must have
[itex]\displaystyle\left|\frac{1}{g(x)}-\frac{1}{L}\right|<\varepsilon[/itex]​
A little algebra shows that
[itex]\displaystyle\left|\frac{1}{g(x)}-\frac{1}{L}\right|=\frac{1}{|L|}\frac{1}{|g(x)|} \left|g(x)-L\right|[/itex]​
Looking at details in the proof, we see that δ1 is used so that there is an upper bound on [itex]\displaystyle\frac{1}{|g(x)|}[/itex]. δ2 is used so that there is a bound on |g(x)-L| .
May I know why must l g(x) - L l < l L l ?
Actually, if you look at the Notes, [itex]\displaystyle \left|g(x)-L\right|<\frac{L^2}{2}\varepsilon\,.[/itex]
This was chosen so that
[itex]\displaystyle \frac{1}{|L|}\frac{1}{|g(x)|} \left|g(x)-L\right|<\frac{1}{|L|}\frac{2}{|L|}\frac{L^2}{2} \varepsilon\,,[/itex]​
whenever
[itex]0<|x-a|<\min(\delta_1,\delta_2)\,.[/itex]​
whenever
And how do we know that: l g(x) - L l < (L x L)ε/2 ?
You seem to be completely missing the point! If [itex]\lim_{x\to a} g(x)= L[/itex], then, for any number [itex]\epsilon> 0[/itex], there exist [itex]\delta[/itex] such that if [itex]|x- a|< \delta[/itex] then [itex]|g(x)- L|< \epsilon[/itex]. Because [itex]\epsilon[/itex] can be any, we can, if we wish, take it to be L, or L/2, or [itex](L^2/2)\epsilon[/itex]. The only thing that changes is how small [itex]\delta[/itex] must. And if we have [itex]\delta_1[/itex] such that if [itex]|x- a|<\delta_1[/itex] then [itex]|g(x)-L|< \epsilon[/itex] and, say, [itex]\delta_2[/itex] such that if [itex]|x- a|< \delta_2[/itex] then [itex]|g(x)- L|<(L^2/2)\epsilon[/itex], then taking [itex]\delta[/itex] to be the smaller of the two, if [itex]|x- a|<\delta[/itex] then both [itex]|x- a|< \delta_1[/itex] and [itex]|x- a|< \delta_2[/itex] are true and so both [itex]g(x)- L|< \epsilon[/itex] and [itex]|g(x)- L|< (L^2/2)\epsilon[/itex] are true.
Ah yes, I get what you mean:) One needs to vary parameters according to the situation:) Thank you v. much!
