Phase cancellation of light - Is it possible to make light disappear?
  • Context: Graduate
  • Thread starter Thread starter infinity3000
    Light Phase
The discussion revolves around the theoretical possibility of cancelling light through interference, akin to noise-cancelling headphones. Participants explore whether it is feasible to create a device that emits light waves in inverted phase to eliminate a light source, thereby creating darkness. The conversation touches on concepts from physics, speculative technology, and science fiction.
  • Some participants propose that light cancellation could theoretically work in principle, but practical limitations exist due to high frequencies and short wavelengths.
  • Others argue that light and sound propagate differently, making it impossible to find a wavelength of visible light that cancels another in the same way sound waves do.
  • A participant suggests that while photon phase cancellation exists, it is not permanent and does not equate to the disappearance of light.
  • Some contributions highlight that interference occurs only at specific nodal points and would not uniformly darken a room.
  • There are suggestions that a device could absorb photons and create new ones, potentially leading to a form of cancellation.
  • One participant mentions that a metal box could serve as a simple solution to block light, questioning the need for a complex gadget.
  • Another participant emphasizes that the concept of "out of phase light" needs clarification in the context of achieving invisibility.
The discussion remains unresolved, with multiple competing views on the feasibility of light cancellation. Some participants assert it is impossible, while others explore theoretical frameworks that suggest it could be achievable under certain conditions.
Participants express varying levels of understanding of the underlying physics, leading to differing interpretations of how light behaves compared to sound. There are references to specific principles and concepts that may not be universally understood among all contributors.
infinity3000
Based on the principle of noise cancelling headphones, I was wondering if it would be possible to do the same thing with light? I.E. If you had a light source and then introduced a device that output a light wave with the same amplitude but with inverted phase, would the interference cancel out the light source and create darkness?
I'm a writer working on a piece with some science fiction elements, so I'm mainly interested in the theoretical possibility rather than actually making something. You can assume that any required technology that we don't have could exist.
I'm not a physicist so please don't just reply with - oh that's not possible due to [insert scientist here]'s Principle. I won't know what you mean. But please if you have any thoughts on how this could be done theoretically or actually, let me know. Thanks
Science news on Phys.org
You don't get to ask a question and also to provide the answer. It can't be done. I know you don't want to hear that answer, but nonetheless, it is the truth.
I wasn't providing the answer, I was just asking people not to dismiss the idea without explanation. Like you did.
I'm happy to hear people say no it isn't possible. There are many things we don't consider possible but then later on someone solves it. And any answer will be limited by current scientific knowledge, whereas science fiction is not.
But with infinite resources and technology we can't yet imagine, is there any current knowledge that could be the basis for this idea?
Actually, you specifically asked for no explanation.
Your argument that since you don't know enough to see that it's impossible therefore it must be possible is illogical. And even though you have asked not to get an explanation, I am going to give you one anyway. If you cancel the light everywhere, you will have the same outcome as if you put an opaque object in front of the light source. That's what it means to cancel the light everywhere. Since obviously, that's not what you want - otherwise you wouldn't need a technological development - whatever it is that you do want is impossible.
"Two plus two continue to make four, despite the whine of the amateur for three and the cry of the critic for five." (J.M. Whistler)
Light and sound do not propagate the same way, so you cannot find a wavelength of visible light that will cancel out another wavelength, as they don't interfere with each other the way sound waves do.
Sound requires a medium to travel through...air typically for our purposes. This means you can generate a wave that will vibrate out of phase and "cancel" the unwanted noise, etc.
Light can be transmitted through a vacuum, and there are no out of phase lights that can be out of phase with it...as there are no vibrations in the air that are produced, etc.
You may need to continue to use an ordinary light switch for now...this will cancel the light for most people. :DIf for science fiction purposes, you can try having a media we don't know about as being the media light is transmitted through, the way air or water, etc, work for sound. You can then have your mechanism follow accordingly.
Thankyou Tea Jay for your thoughtful and helpful response. It is interesting to hear about the differences between light waves and sound waves; the fact that light waves don't interfere with each other sounds like the main reason why light cancellation wouldn't work.
Vanadium 50 please cease posting in this thread and go "mentor" somewhere else.
It can be done in principle but in practice the frequencies are simply too high for any coherent electronics to function, and the wavelengths are simply too short for antennas on the wavelength scale to be anything but fragile.
The physics of it is quite straitforward though.
The photons either pass through each other or form mass. If they form mass, they did not disappear. If they pass through each other, they only cancel their phases so as long as they overlap that way. Once they already passed each other, they are separating from each other and no longer cancel their phases.
Photon phase cancellation exists, but it is never permanent. And to be more precise about it, not everything about the photons gets cancelled. Cancellation of phases doesn't mean cancellation of their existence. Light doesn't "disappear".
Short answer: No.
Using only passive means the answer is no. But using electronics the answer is yes.
Your equipment would absorb photons and create new ones. It's not difficult.
Of course they do. Waves are waves and interference is interference. Sound and light interfere in exactly the same way.
LOL - I meant in his context of an explanation w/o an explanation.
For example, given his context, probably to have a science fiction device that can "cloak" etc, it would emit such an interference to cancel out the light analogous to the way noise cancelling headphones do for sound, etc.
What would "out of phase light" be that would therefore cancel out the visible light if they are exactly the same, in the context that he is going for?
IE: Sure, they can interfere, and I winced a little due to oversimplification, but not the way he wants them to.
Again, I was assuming he was going for invisibility to hide a person or ship, etc.
To clarify, the effect I am interested in producing would be along the lines of a windowless room with a single light source, and then introducing an electronic device which emits photons in such a way as to "cancel" out the photons from the light source, effectively putting the room into darkness.
Sorry if I'm oversimplifying or mangling the terminology...
Don't forget, that when two waves with mediums are interfering, it's not like they interfere everywhere. They interfere destructively only at SPECIFIC nodal points, meaning that it wouldn't work to thrust an entire room into darkness.
This is only the case with certain source distributions. In general it is not true.
For example, a spherical surface distribution of electric and magnetic currents enclosing the light bulb could completely cancel its emissions.
The magnetic currents cannot be realized directly but are approximated (mathematically and in the engineering sense) by small electric current loops whose axis is parallel to the surface enclosing the lamp.
Look up "Schelkunoff's equivalence principle" for the equations behind this.
Yes, but let's consider the sort of charge distribution that will cancel an arbitrary (and incoherent) light source - you'd want something like a metal box. Well, in that case, why not use a metal box? Or a wooden box.
Any scheme you are going to come up with requires the gadget to be in between the eyes and the object. And, by definition, the response of this gadget will be the same as if it were opaque. And we're back to the box.
Use Dark Sucker theory in your book.
http://www.rogermwilcox.com/darksucker.html
I have some sympathy for infinity 3000, in PRINCIPLE cancellation is possible...isn't that called interference? What he makes of that is up to him to research and good luck to him and his imagination in his area.
"two plus two continues to make four, despite the whine of the amateur for three and the cry of the critic for five"
If J.M Whistler had any background in basic vector mathematics he may have had a different view.
Pythagaros knew that 2 + 2 could be √8
You are not looking for a specific change. you are looking for complete change.
It's easy really.
Refract all light so that it's either higher or lower than the spectrum of human visibility.
No calculations are needed.
It does the job of canceling it out, without actually thinking about it. Now, if you wanted to cancel out specific lights, that would be more fun. Say, cancel all light that is not in the field of vision of an individual.
You didn't actually think you would receive a positive reply detailing methods and application did you ? I realize my reply is long overdue and will simply tell you why I initially came to ask the same question. Many years ago a Rapier Squadron tracked on radar a US Stealth Aircraft coming into land at a UK Base, the guy in question puzzled by this asked one of the US Officers on station how this was possible, the reply he received was " Son, when that that thing doesn't want to be seen you won't see it" Now then, maybe that's why you won't see a true answer to your excellent and thought provoking question.
But the physics of the stealth fighter actually isn't that much of a secret. If you read the book "Skunk Works", you'll realize the history of the physics involved, and the fact that it was contained in a rather old russian paper on a particular E&M problem. What is classified is how it is achieved and the kind of material used to turn that into reality.
That is not the same here. The OP has received several answers that essentially explain why what is trying to be accomplished isn't that clearly obtained based on the physics, not just trying to find a way to achieve it. There's a distinct difference here.
Zz.
I see redirection and no explanation, I see a Mentor that cannot refute and will not admit to possibilities that technology already exists to which the Mentor is not privy to
This is silly. Why would I refuse something if the technology already exist? If it does, show it! If not, then you are on a fishing expedition and making speculative, unfounded claim, which is in violation of the rules that you had agreed to. The redirection was done by you by bringing up the stealth technology, which I've explained why it is NOT the same as this topic.
The original question was addressed. It may not have been addressed to your liking. Unless you have definitive sources to indicate otherwise, then you have not provided anything of value other than stirring the pot.
Zz.
My apologies, I should have made myself clear, The publication you refer to In my opinion exists as nothing more than redirection from the actual physics used by the US Air Force.
Did you actually read it?
Again, the physics involved was published out in the open. Even Wikipedia has a good entry on it!
http://en.wikipedia.org/wiki/Stealth_technology
The Russian publication that I referred to, which was cited in that book, was Ufimtsev's "Method of Edge Waves in the Physical Theory of Diffraction".
Again, the physics was there, unlike this current topic. The comparison you made is not valid.
Zz.
The fundamental problem with canceling light is that the interference will be constructive in just as many places as it is destructive. If it were possible to know the exact location of the observer (by observer I mean each cone or rod cell in each eye or each pixel of a CCD etc.)and the exact location and phase of each photon headed in that direction you could generate photons which would cancel at the observers location, though in other locations they would not. Even this is impossible though due to Heisenberg's uncertainty principal. Since photons are small enough that quantum effects are significant the uncertainty principal will prevent you from knowing exactly where and at what phase a photon is as it travels from source to observer. Since you cannot know the position and phase of each photon you cannot consistently generate photons that will cancel them.
(Bold added by me)
That is a very important part. Sound is (relatively) easy to cancel as it is coherent - you can measure where sound is, and predict how sound will arrive at the observer. This is not possible with most light sources, like the sun or a light bulb.
You can cancel laser light at some specific location, with a different laser (or different path of the same laser) carefully tuned to the same frequency and the appropriate phase. The same is true for radio waves, microwaves and similar coherent low-frequency electromagnetic waves.
What exactly are you referring to?
Are you talking about introducing an infinite set of Fourier components and somehow producing a flat (zero amplitude) line? Is this even possible mathematically?
If you completely cancel out the light wave, the light doesn't disappear. It never was emitted in the first place. Pretty hard to achieve with visible light, but if you put a radio antenna in a cavity such that the radio emission would interfere with itself, then the antenna would not radiate at that frequency.
This is not right. You can only get cancellation from two coherent sources (identical frequencies / wavelengths), whatever sort of waves you are considering.
The only significant difference between light and sound, in this respect is the wavelengths and frequencies involved.
@Infinity
Sound cancelling headphones / enclosures also rely on the possibility of electrical circuitry working fast enough to produce exactly inverse signals (sets of waves, if you like) to cancel the unwanted ones which are arriving. It is possible to pick up the sounds right next to your ear (wanted programme signals and unwanted noise from outside) with a microphone and use electronics (negative feedback) to cancel most of the unwanted stuff. Nothing will work fast enough to achieve the same thing with light. This is not just a matter of technology getting better in time; it's pretty fundamental.
There is an alternative way (of thinking, more than fundamentally different) to cancel a wave and this is to mimic the wave precisely and add it (inverted version) to the incoming wave, producing a cancellation. Unfortunately for your scheme, the geometry of the situation means that cancellation will only operate over a very small region and, for different wavelengths, the cancellation will work at different places. If you look at the Young's Slits interference experiment, you will see that two sources can produce narrow fringes of cancellation. It only gives good cancellation for just one wavelength and it's hopeless with sunlight (a huge spread of wavelengths involved).
So the answer is NO and my explanation is about as simple as it can get, I think. Sorry. :frown:
Can I make a general request that people do not talk in terms of "Photons interfering"? It can b e very confusing for someone new to the subject. The two concepts are from entirely different parts of Physics. Interference is a classical phenomenon and has to do with Waves. Photons are Quantum particles and are only relevant when discussing quantum phenomena. (But this is not really part of a discussion of 'stealth' methods).
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 40 ·
  • · Replies 68 ·
15K
