How Do You Calculate Work Done by Gas in Thermodynamics?
  • Thread starter Thread starter Enoch
    Thermodynamics
The work done by a gas during expansion at constant pressure can be calculated using the formula W = P(Vf - Vi). In this discussion, the gas expands from an initial volume of 5 L to a final volume of 10 L under a pressure of 95 atmospheres, which converts to 9623500 Pascals. The correct calculation requires converting the volumes from liters to cubic meters, where 1 m³ equals 1000 L. The accurate work done by the gas is 4811750 Joules, confirming the importance of proper unit conversion in thermodynamic calculations.
  • Understanding of thermodynamic principles
  • Familiarity with unit conversions (atmospheres to Pascals, liters to cubic meters)
  • Knowledge of the work formula in thermodynamics (W = P(Vf - Vi))
  • Basic proficiency in handling SI units
  • Study the ideal gas law and its applications in thermodynamics
  • Learn about pressure-volume work in different thermodynamic processes
  • Explore unit conversion techniques for various physical quantities
  • Investigate common mistakes in thermodynamic calculations and how to avoid them
Students studying thermodynamics, engineers working with gas systems, and anyone involved in physics or chemistry requiring accurate calculations of work done by gases.
Enoch
Thermodynamics problem: help needed!
Gas in a container expands at a constant pressure of 95 atmospheres. Find the work done by the gas if the initial volume is 5 L and the final volume is 10 L. Answer in units of Joules.
I thought this problem was straight-forward, but I missed it.
I converted 95 atmospheres into Pascals.
95 X 1.013e5 PA = 9623500
I then converted L into meters ^3.
Vi = 0.5 m^3
Vf = 1 m^3
With the units converted, I used the equation W = P(Vf - Vi) and got the answer 4811750 Joules. The answer is incorrect, or so I believe.
Where did I go wrong?
Vi = 0.5 m^3
Vf = 1 m^3
There's no problem with the conversion of the pressure's units to SI,but remember that
[tex]1m^3=1000L[/tex]
Thanks a lot!
