| New Reply |
Proving non-existence of integer solutions by reducing mod p |
Share Thread | Thread Tools |
| Jan4-12, 05:01 PM | #1 |
Say I have the equation a^2 - 10b^2 = 2. So even though this is an equation in two variables and not one, I can still reduce mod P to a^2 = 2 (mod 5) and use the fact that it has no integer solutions mod 5 to conclude the original equation has no integer solutions, correct? Also does this only work modulo a prime, or can I do this modulo any natural number?
| Jan4-12, 05:46 PM | #2 |
If there was an integer solution, that would also be a solution to the reduced-modulo-5 version. And since there isn't a solution to the reduced-modulo-5 version, there isn't an integer solution. A (polynomial) equation doesn't have a solution modulo 6 if and only if at least one of the following is true:Incidentally, it's fairly common that 4 and 8 are more useful to consider than 2. |
| Jan4-12, 05:52 PM | #3 |
Ah yes, that makes sense, thanks =].
| Jan5-12, 12:23 AM | #4 |
Would someone mind showing the steps to reducing that? (a^2-10b^2=2 to a^2 = 2 mod 5)
| Jan5-12, 01:09 AM | #5 |
Recognitions:
[13] = [3]. a2 - 10b2 = 2 (given equation to solve) [a2 - 10b2] = [2] (reducing both sides modulo 5) [a2] - [10b2] = [2] (because mod 5, [x+y] = [x] + [y]) [a]2 - [10][b]2 = [2] (because mod 5, [xy] = [x][y]) [a]2 = [2] (because [10] = [0] mod 5) one can explicitly compute [a]2, for a = 0,1,2,3, and 4: [0][0] = [0] [1][1] = [1] [2][2] = [4] [3][3] = [9] = [4] [4][4] = [16] = [1] or, using an "old-fashioned method": let a = a' + 5k let b = b' + 5m then a2 - 10b2 = (a' + 5k)2 - 10(b' + 5m)2 = (a')2 + 10a'k + 25k2 - 10(b')2 - 100b'm + 250m2 collecting all obvious multiples of 5, we get: = a'2 + 5(2a'k + 5k2 - 2b'2 - 20b'm - 50m2) let n = 2a'k + 5k2 - 2b'2 - 20b'm - 50m2, then we have: a'2 + 5n = 2, that is: a2 = a'2 = 2 (mod 5). |
| Jan6-12, 06:58 PM | #6 |
Oh, that makes sense. I actually did some of those, using the "old fashioned method," in my proof class, but only of a single variable. It was the second variable that threw me off. Thanks for the great explanation.
| New Reply |
| Thread Tools | |
Similar Threads for: Proving non-existence of integer solutions by reducing mod p
| Find all integer solutions to .... | Calculus & Beyond Homework | 1 | ||
| Proving the existence, or non-existence, of unbiased estimators | Set Theory, Logic, Probability, Statistics | 0 | ||
| proving that a^2-2b^2-4c^2 = 0 has no positive integer solutions | Calculus & Beyond Homework | 3 | ||
| integer solutions | Linear & Abstract Algebra | 15 | ||
| Proving an integer is prime | Introductory Physics Homework | 5 | ||
