Asperity density and asperity radius of curvature
The discussion revolves around the concepts of asperity density and asperity radius of curvature, particularly in the context of contact analysis of rough surfaces. Participants seek clarification on these terms and their relationship to summit radius and area per summit, as well as their application in models like Greenwood-Tripp's.
  • Asperity density is described as the number of asperities (roughness peaks) per unit area.
  • The radius of curvature refers to the radius of the top of the asperities that make contact with another body, with some participants suggesting it could be considered as an average value across multiple asperities.
  • One participant inquires about the possibility of measuring the asperity radius of curvature and mentions using the Greenwood-Tripp model.
  • Another participant shares resources and references for understanding the influence of surface roughness in contact models, including specific articles and a book by K.L. Johnson.
  • There is mention of the factor involving asperities being of second order importance in the context of the discussed models.
Participants generally agree on the definitions of asperity density and radius of curvature, but there is no consensus on the specifics of measuring these parameters or their implications in different models.
Some participants express confusion regarding variables in the Greenwood-Tripp model, indicating that further clarification on these terms and their applications may be needed.
TLDCC
Hi guys,
The terms above (asperity density and asperity radius of curvature) have confused me for quite a while. I've no clue what they are. Could anyone give me a hand? And is there any relation between them and the summit radius & area per summit? Thanks!
CC
TLDCC said:
Hi guys,
CC
Hi TLDCC,
I guess you refer to the contact analysis of rough surfaces? In that case, the asperity density is the number of asperities (roughness peaks) per unit area. The radius of curvature is the radius of the top of these asperities (that makes contact with the other body).
Jaap
Walker59 said:
Hi TLDCC,
Jaap
Hi Jaap, Thanks for your reply! That does help me. Do you mean the radius of curvature is the average of the radius of all the tops?
Thanks,
TLDCC
Hi TLDCC,
In a general contact of rough surfaces, there will be multiple asperities in contact and its undo-able (virtually impossible) to analyze each asperity individual. So yes, the average value will be a good measure.
What is the background of your question?
Jaap
Walker59 said:
Hi TLDCC,
Jaap
I'm using the Greenwood-Tripp's model but some of the variables confused me. Is there any way to measure the asperity radius of curvature?
TLDCC
Hi TLDCC,
That is a coincidence. I'm looking into this model too. I'm busy updating my freeware program HertzWin (see under Toolkit at en.vinksda.nl) with surface roughness influence.
The best I've found so far is to use the graph of the model with the coefficient alpha against P_rough/P_Hertz. You can find in the book of K.L Johnson. Or online in articles like "Deformation due to contact between a rough surface and a smooth ball" from Jamari and Schipper (they did a curve-fit). Or "a compact model for spherical rough contacts" from M. Bahrami et all.
The factor that has the asperities in it is of second order importance.Jaap
  • · Replies 20 ·
  • · Replies 29 ·
  • · Replies 20 ·
  • · Replies 17 ·
