New Reply
Integrate vector in rotating frame?
Share Thread Thread Tools
Jan6-12, 11:00 AM   #1
Hi.
Ok, so I'm trying to understand the "navigation equations".
n: frame traveling on earth with vehicle.
e: frame centered in earth, rotating with it.
P: Position of vehicle center of gravity.
v[itex]^{n}_{P/e}[/itex] = (vn,ve,vd): velocity of P w.r.t to e-frame, expressed in n-frame.
Normally you don't integrate this, but uses vn,ve,vd to calculate the derivative of longitude,latitude,height and then integrate these to get position in longitude,latitude,height.
BUT, my question is: what do you get if you integrate vn,ve,vd?
I mean, normally when you integrate vectors:
- the frame is fixed in space
- you have a velocity w.r.t this frame
- and you just integrate each component separately
But now
- the frame is rotating
- velocity is not w.r.t this frame
Any thoughts?
/Jonas
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan6-12, 04:22 PM   #2
RCP
Bump. My only thought is I so wish some of the cognoscenti here would comment on your questions Hare. I suspect perhaps a few are brave enough to jump into this rabbit warren with no visible bottom. Certainly not I, but some answers here might be helpful on a related subject. Anyone?
New Reply
Thread Tools
Similar Threads for: Integrate vector in rotating frame?
Thread Forum Replies
rotating frame + heat Introductory Physics Homework 9
definition of a rotating frame in GR? Special & General Relativity 5
Defining a Lagrangian in an rotating reference frame frame Classical Physics 4
Rotating & Translating Frame Atomic, Solid State, Comp. Physics 0
Acceleration in a rotating frame Classical Physics 4
