Evaluating a Surface Integral: xze^y i -xze^y j +z k
The discussion focuses on evaluating the surface integral of the vector field F(x,y,z) = xze^y i - xze^y j + z k over the surface defined by the plane x + y + 2z = 2 in the first octant, oriented downwards. The initial setup involves transforming the integral into a double integral over the region R, with a substitution for z based on the plane equation. The user expresses uncertainty about the correctness of their approach and whether further substitutions are needed in the integral. The complexity of the integral is acknowledged, indicating a challenging problem. The thread seeks confirmation and guidance on the evaluation process.
bugatti79
Evalute the surface integral
F(x,y,z)=xze^y i -xze^y j +z k for the surface is partof the plane x+y+2z=2 in the first octant and orientated downwards
\displaystyle \int \int_{\sigma} F dS=\int \int_R (xze^y i -xze^y j +z k)(z_x i+ z_y j -k) dA=\int \int_R (x^2z^2e^y-xyz^2e^y-z) dA
Is this correct so far...if so have I to substitute for z and put in above integral. Looks like a difficult integral...?
Something like
\displaystyle \int \int_{\sigma} F dS=\int \int_R (xze^y i -xze^y j +z k)(z_x i+ z_y j -k) dA=\int \int_R (x^2z^2e^y-xyz^2e^y-z) dA \implies
\displaystyle \int \int_{\sigma} F dS=\int \int_R (x^2(\frac{2-x-y}{2})^2 e^y-xy(\frac{2-x-y}{2})^2 e^y-(\frac{2-x-y}{2})) dA.?
Posted at this link also. Will notify both forums of any responses. Thanks
http://www.freemathhelp.com/forum/threads/73614-surface-integral
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
