Why don't static shocks kill you?
by bhoot
Tags: current, electicity, shocks, static, voltage
bhoot
bhoot is offline
#1
Jan8-12, 10:59 AM
P: 6
I know that lightning can, but look at the following example: A Van de Graaff generator can produce lots of volts. Lats say 100 KV for our purposes. Why doesn't this voltage kill you? Many people say that it doesn't have enough amps, but lets look at Ohms law: V = IR. I measured the resistance from one hand to the other as being 750,000 ohms in my body. That means that there are 100000 Volts/750000 Ohms = 0.13 amps going through your body. It only takes 65 milliamps to stop your heart. There have been many class demonstrations where a student holds a Van de Graaff generator and touches someone else to pass hundreds of thousands of volts through their body. Why does't this kill you?
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
rollcast
rollcast is offline
#2
Jan8-12, 11:10 AM
P: 418
Because electricity takes the path of least resistance to get to ground and that doesn't usually involve passing into the body.
Dickfore
Dickfore is offline
#3
Jan8-12, 11:17 AM
P: 3,015
Also, even if it goes through the body, it still completes a loop through air (do you actually touch the Van der Graff generator, or simply approach your finger)? Furthermore, how did you find that the resistance of your body is only 750 kΩ?
Integral
Integral is offline
#4
Jan8-12, 11:30 AM
Mentor
Integral's Avatar
P: 7,291
Typically Van de Graffs only generate a few micro Amps. Way below a fatal current which is usually given as 10 to 50 milli amps.
bhoot
bhoot is offline
#5
Jan8-12, 11:31 AM
P: 6
There is no path for the electricity to go but through your body. You actually touch the generator (while standing on an electrical insulator so that electricity can't pass through your feet to the ground), and then touch another person. I got 750,000 ohms by measuring my body with a multimeter.
bhoot
bhoot is offline
#6
Jan8-12, 11:33 AM
P: 6
Quote Quote by Integral View Post
Can you explain how the amperage is low even though the volts are high? I have some numbers in the original post, 100 kV for the generator and 750,00 ohms for the body. I get .13 amps. with V = IR.
russ_watters
russ_watters is offline
#7
Jan8-12, 11:36 AM
Mentor
P: 22,001
V=ir and the numbers you are trying to plug in only apply to a steady state. The van de graf just doesn't store enough energy: it gets dissipated long before affecting your heart.
bhoot
bhoot is offline
#8
Jan8-12, 11:43 AM
P: 6
Quote Quote by russ_watters View Post
Ok, I suppose that explains it. Where exactly does the energy dissipate to?
Integral
Integral is offline
#9
Jan8-12, 11:44 AM
Mentor
Integral's Avatar
P: 7,291
No power supply exists which can produce an unlimited current every supply is current limited in some way. A Van de Graff, or a door knob for that matter, can only produce a "few" electrons for current flow. It may be at a very high potential but the current flow is limited by the electrons available. I quoted few because of the huge numbers involved in these processes.
russ_watters
#10
Jan8-12, 11:47 AM
Mentor
P: 22,001
Quote Quote by bhoot View Post
Well that's just it: there is very little energy to dissipate in the first place! Almost all woulg get dissipated right at the site of the shock.
bhoot
bhoot is offline
#11
Jan8-12, 11:50 AM
P: 6
This may be slightly off topic from the static electricity, but what about transformers then? Would 120 volts from house power taken up to as 100,000 volts with a transformer be able to supply enough current?
Antiphon
Antiphon is offline
#12
Jan8-12, 11:56 AM
P: 1,781
There is more than enough current in a carpet shock to kill you. But there isn't enough charge (not enough capacitance) to sustain the otherwise lethal current.
DrZoidberg
DrZoidberg is offline
#13
Jan8-12, 01:37 PM
P: 371
The resistance from one hand to the other is about 1,000 Ohms. 750,000 Ohms is the resistance of your skin. But when the voltage is high enough, the skin looses it's resistance and you are left with the 1,000 Ohms of internal resistance. A Van de Graaff generator can not produce much current. Let's say it's current is 10 ľA. V = I*R. 10ľA * 1,000 Ohms = 10 mV. That's the voltage that drops over your body. 100,000 V is what you get when the generator is insulated from ground. When the generator is grounded, whether it's through your body or through a wire, the voltage drops to nearly nothing. Btw. a Van de Graaff generator is a constant current source. It's output current is always the same independent of what resistance is attached to it.
Containment
Containment is offline
#14
Jan8-12, 05:38 PM
P: 18
It's sorta like this but not exactly... If I toss 1,000 pillows at you very softly you probably will just think it's a pillow fight but if I toss 2 or 3 pillows at you fired from a cannon at 1,000 mph your brains will go splat. Same deal with electricity the pillows are basically the voltage and the amperage is basically the speed they are moving at. So as long as the amperage is low enough below like 1 amp you probably wont die from the shock alone.
mrspeedybob
mrspeedybob is offline
#15
Jan8-12, 06:49 PM
P: 686
Quote Quote by Containment View Post
This is incorrect.
1 amp is a large amount of current when considering electric shock. 1/20 of that could kill you.
Containment
#16
Jan8-12, 07:37 PM
P: 18
I wasn't trying to be super accurate as obviously even a low amperage shock could kill you given it hits you in the right spot or for long enough. You obviously don't want to be messing around with anything electrical if you don't understand it. Also something to consider is that while a dc shock may not kill you electrically when you get tossed 6 feet away into the wall you might die. With that said humans are fairly resistant to electrical shocks for example farmers have to bring in cows from thunderstorms not because of rain but because if a bolt of lightning hits the ground the electricity passing through the ground could be enough to kill them while a human would probably be fine.
bhoot
bhoot is offline
#17
Jan8-12, 08:59 PM
P: 6
So what exactly does it mean that when you bring up voltage with a transformer, you lose current?
Integral
Integral is offline
#18
Jan8-12, 10:08 PM
Mentor
Integral's Avatar
P: 7,291
A transformer that steps up voltage will step down current in the same ratio. If secondary voltage is 10x the primary voltage the secondary current will be .1x the primary current.
Power in must equal power out and power = Current x Voltage.
Register to reply
Related Discussions
How can static electricity shocks from treadmill be prevented? General Engineering 24
Static Shocks Occurrence General Physics 1
How can I separate the thermal energy from kinetic? Astrophysics 0
UK taking physics and looking to study aero eng. Mechanical Engineering 1
Need help: car shocks Classical Physics 1
