Writing a physics report about hydrochloricacid
The discussion revolves around the production of hydrochloric acid (HCl) from sodium chloride (NaCl) and sodium bisulfate (NaHSO4), and the implications of diluting HCl with water to achieve high concentrations. Participants are exploring the chemical reactions involved and the properties of HCl in solution.
  • Participants are questioning the validity of producing concentrated hydrochloric acid by adding a specific ratio of HCl to water. There is also discussion about the nature of the reactions and the strength of the acids involved.
Some participants are providing insights into the limitations of HCl solubility and the effectiveness of the proposed reaction. There is an acknowledgment of differing methods for producing HCl, with some suggesting that alternative reactants may yield better results.
Participants note constraints regarding the use of sulfuric acid due to safety concerns, which affects the methods available for producing hydrochloric acid.
Cr4X
I am writing a physicsreport about hydrochloricacid, but I have a quick question, and I don't have time to ask my teacher so I hope you can help me.
I am making hydrochloricacid from NaCl and [tex]NaHSO_4[/tex], then I get HCl and [tex]Na_2 SO_4[/tex], and when let the HCl get in contact with water it becomes acid. My question is, can you then make 100% (or 99% if you want) hydrochloricacid by adding 470 times more HCl as water or is the HCl somehow not as strong as if you had done it other ways?
I know this may sound incredible stupid, but I want to be 100% that my answer is correct.
Thanks a bunch in advance.
If that is correct then what I am being thought is wrong (which shouldn't really surprise me that much, although what I have been taught here made sence). Let me try explaining this again.
We were warming it up, so that:
[tex]NaCl + NaHSO_4 > HCl + Na_2 SO_4[/tex]
If I didn't make HCl what the **** was that gas making me cough then?
What does 100% refer to?
The molarity or..?
Hydrogen chloride is not extremely soluble as hydrogen iodine in water.
There is a limit of decomposition of HCl. After that any HCl gas put in stay in form of gas in the water as it can't dissolve.
100% refers to how concentrated the acid is. Like you can have 2M acid. 100% is simply the most concentrated hydrochloricacid you can get (that is 470 times more HCl than water).
My question is if it is possible to make 100% concentrated hydrochlrocicacid by just adding 470 times more HCl than water, no matter how the HCl was created?
"Hydrochloric acid" is two words!
Oh sorry, english isn't my primary language... but I got to admit it was pretty hard to spell in one word :)
Well,your reaction is not going to go that easily,since the poor choise of reactants.Note that the ion [itex]HSO_{4}^{-}[/itex] has a smaller acid constant (is a weaker acid) when it loses a proton,than the neutral [itex]H_{2}SO_{4}[/itex] losing a proton.So my,guess is that u get more HCl by puttin' sulphuric acid over a salt of the hydrochloric acid,and to prove it,cf.
[tex]NaCl+NaHSO_{4}\rightarrow Na_{2}SO_{4} +HCl[/tex]
[tex]2NaCl+H_{2}SO_{4} \rightarrow Na_{2}SO_{4} +2HCl[/tex]
Daniel.
That is true, and I have mentioned that way in my report as well, but we are currently not allowed to make it from sulphuric acid, as it is too dangerus for some reason.
Anyway, thanks for your help just wanted to be sure that what I wrote was correct.
  • · Replies 43 ·
