Why does liquid cool down when it evaporates?
  • Context: High School
  • Thread starter Thread starter meg_radcliffe
    Cooling
The discussion revolves around the phenomenon of cooling in liquids during evaporation, exploring the underlying mechanisms, definitions of heat, and the interplay of temperature and kinetic energy. Participants examine theoretical explanations, practical implications, and the nuances of energy transfer in different conditions.
  • Some participants propose that evaporation removes heat through the "heat of vaporization," suggesting that the loss of faster molecules reduces the mean kinetic energy and thus the temperature of the liquid.
  • Others argue that the concept of heat transfer is more complex, noting that cold water can evaporate into warmer air and questioning the traditional definition of heat as energy moving from warmer to cooler bodies.
  • A participant highlights that the net energy flow during evaporation depends on the temperature difference and humidity, suggesting that under certain conditions, evaporation may not lead to cooling.
  • There is a discussion about the role of surrounding air and convection, with some noting that hot air can increase the kinetic energy of the liquid, potentially counteracting the cooling effect of evaporation.
  • One participant challenges the notion of latent heat, suggesting that modern understandings of molecular behavior do not support the idea of heat being "hidden" in molecules during phase changes.
Participants express multiple competing views on the mechanisms of heat transfer during evaporation, with no consensus reached on definitions of heat, the role of latent heat, or the conditions under which cooling occurs.
Some statements rely on specific definitions of heat and energy transfer, which may vary among participants. The discussion includes assumptions about temperature differences and environmental conditions that are not universally agreed upon.
This discussion may be of interest to those studying thermodynamics, physical chemistry, or anyone curious about the principles of evaporation and heat transfer in liquids.
meg_radcliffe
Can someone please explain to me why a liquid cools down when it evaporates:-D
Science news on Phys.org
A more 'nuts and bolts' explanation is as follows. Molecules in the water have a range of kinetic energies. The faster molecules on the surface have enough energy to take them up into the surrounding air and to become part of the surrounding water vapour.
It is the Mean KE of molecules in the water that determines the Temperature and, having lost some of the faster molecules, the mean KE is reduced - hence the temperature drops.
Once the air near the surface is 'saturated', there will be as many molecules returning (adding their KE to the rest) as leaving so net evaporation will be zero and the temperature will cease dropping. This loss and return of molecules is often described in terms of 'vapour pressure' (changes of Momentum on the surface).
When there is a current of unsaturated air over the surface, the escaping molecules get swept away from the surface and so more evaporation will take place, reducing the temperature further (e.g. on the washing line on a windy day or standing in a wind after a swim).
This explanation does away with the notion that air is, somehow, like a sponge - absorbing the water. The molecules of water vapour are in no way different from the O2 and N2 molecules also in the air; all three gases exert their own pressure and add it to the final pressure in the air. The same vapour pressure would exist over the surface of water if it were in a container which had been initially evacuated.
That's a really nice explanation.
russ_watters said:
Evaporation removes heat. "Heat of vaporization".
I don't believe that's always true, Russ. Cold water will evaporate into warmer air quite readily. If we define heat as energy that moves from a warmer body to a cooler one solely because of the difference in temperature, then this KE of vaporization is not heat.
Moreover, these vaporizing water molecules do not "carry" any latent heat. We know a lot more about molecular structures now than we did when Black first proposed his hypothesis of "latent" (hidden) heat back in the 1850's. Quantum physics has given us a pretty good insight into both the internal and external mechanisms by which energy is stored and expressed by molecules. There has been no convincing evidence of latent heat or enthalpy of transformation stored anywhere--hidden or overt--in liquid or gas molecules.
If the water is hotter than the air, then some net amount of heat will be transferred from the water to the air. If the water is the same temperature or cooler than the air, then no net amount of heat will be transferred to the air. Enthalpy transfer, yes. Heat transfer, no.
Energy will be lost due to evaporation but gained due to the temperature difference. If you covered the surface of the water with a thin layer of oil, it would warm up quicker than with the surface uncovered. This is how one can normally stay alive in a sauna!
The actual net flow direction will depend on the relative temperature difference and the relative humidity. You will die in a sauna full of vapour because your sweating will not produce sufficient evaporation.
You are right to say that molecules don't "carry latent heat" because one is a microscopic concept whilst the other is macroscopic. The escaping molecules still carry energy away, though.
Also note that the hot air surrounding the liquid heats up the liquid and increases the KE of the molecules in the liquid. There are cases (combination of certain liquids and initial temperatures) where the cooling due to evaporation is smaller than the heating due to convection of heat from the surrounding into the liquid, and the net effect is a heating of the liquid. But the cooling 'term' in the heat balance equation is due to evaporation.
  • · Replies 32 ·
16K
  • · Replies 109 ·
10K
  • · Replies 30 ·
16K
