Will a 5 kg Block Slide on a 50 Degree Incline Plane? Calculation and Answer
The discussion revolves around a physics problem involving a 5 kg block on a 50-degree incline plane with a coefficient of friction of 0.5. Participants are exploring whether the block will slide down the incline based on the forces acting on it.
  • Participants discuss the forces acting on the block, including gravitational components and frictional forces. Some question the conditions under which the block will slide, while others suggest exploring the coefficient of friction required to prevent sliding.
The discussion is active, with various interpretations of the forces involved. Some participants have provided insights into the calculations and conditions for sliding, while others are questioning the assumptions and exploring alternative scenarios.
There are mentions of common problems related to finding the coefficient of friction that prevents sliding and the angle at which the block will not slide, indicating a focus on understanding the underlying principles rather than reaching a definitive conclusion.
tony873004
This is just a question I made up because there'll probably be one like this on our final exam.
A 5 kg block is on an incline plane of 50 degrees. coeffecient of friction is 0.5. Will it slide?
N = mg cos(50)
N = 31.529
friction = mu * N
friction = 15.764
force down = ma
f =m g cos(50)
f = 31.529
force down > friction so it will slide.
Actually the force making it slide it's the x component of gravity [itex]mg \sin \theta[/itex]
and yes if [itex]mg \sin \theta > \mu mg \cos \theta[/itex] then it will slide.
Thank you...
Why don't you try finding the coefficient of friction that will avoid the system from sliding or finding the angle it will not slide an a specific coefficient of friction? Those are some of the common problems asked.
if it slides when mg sin theta > mg cos theta, then when they equal that should be the minimum mu necessary to keep it from sliding.
mg sin theta = mu mg cos theta
mu = (mg sin theta) / (mg cos theta)
but this gives me an answer greater than 1.
Because the inequality says [itex]\tan \theta > \mu [/tex] that's why you are getting a greater value.[/itex]
  • · Replies 27 ·
11K
  • · Replies 19 ·
