Projecting 3D point to 2D / view-point
  • Context: Undergrad
  • Thread starter Thread starter onako
    2d 3d Point
The discussion revolves around the concept of projecting 3D points onto a 2D space, specifically focusing on the mathematical representation of this process using matrix multiplication. Participants explore the meaning of "projection" in this context, considering different viewpoints and the implications of the projection surface.
  • One participant describes their understanding of projection as changing the viewpoint from which 3D data is observed, suggesting that each matrix P corresponds to a different viewpoint.
  • Another participant presents two perspectives on projection: one relative to the standard basis of 3D space and another relative to the basis of the 2D projection plane, emphasizing the importance of the orientation of the 2D plane.
  • A later reply introduces the concept of orthogonal projection and provides a formula for it, noting that the projections are stored as column vectors in a different orientation compared to the original data.
  • One participant mentions the property of projections where applying the projection multiple times yields the same result, highlighting a fundamental characteristic of projection operations.
  • Another participant agrees with the initial interpretation of projection but adds the concept of a "projection surface," suggesting that the matrix multiplication could represent both a change of viewpoint and the projection surface itself.
  • Further clarification is provided regarding standard orthogonal projections, indicating that the projection surface can be represented mathematically as an oriented plane.
Participants generally agree on the basic understanding of projections but express differing views on the implications of the projection surface and the mathematical representation of the process. The discussion remains unresolved regarding the best approach to define and implement these projections.
Participants note the importance of understanding the orientation of the projection plane and the implications of using different types of projection matrices. There are references to specific mathematical properties and formulas that may require further exploration for clarity.
onako
Recently I was assigned to implement a procedure involving "3D projections" to "2D space". Supposing that 3D data is stored in a n x 3 matrix X, the final step involves Y=XP, where P is a 3x2 matrix. However, I would need to be sure about the actual meaning of the word "projection" to 2D. In my understanding (I deliberately tend to be descriptive), there are some points in 3D, I'm looking at it from above, and there is a piece of paper below the data (paper is fixed).
So, each time I multiply XP to obtain Y in 2D, it actually means I'm changing the viewpoint, and Y actually corresponds to what I see when looking at the data (as on the fixed paper), right? In other words, with every P, I'm changing the viewpoint and taking the picture (or drawing on a paper, thus 2D) of what I see? If so, that would mean that for any P there is a viewpoint. Please correct me if I'm wrong.
There are two ways of viewing the projection.
First, you view the projection on the 2D plane with respect to the standard basis of 3D space. That is the same coordinate system used by the row vectors in that n-by-3 matrix, X.
Second, you view the projection with respect to the basis of that 2D plane.In any case, you need to know how is your 2D plane orientated.You get the second type projection if you use your method Y = XP such that each of the two columns of P has length = one and they are perpendicular to one another. (Sorry for those who read orthogonal matrix before edit, I was very tempted to use the term here)
To get the first type projection, I can think of a view ways to do it but I will give you the most straight forward solution (in terms of theory) that I know - orthogonal projection. If you use software like MATLAB, pseudoinverse is even simpler to use to get the solution but the theory behind it is not as easy.
Since you store your 3D coordinates as row vectors of matrix X then this is the way to do it. I give you straight solution. If you want the theory check out orthogonal projection.
[itex]Y = A(A^TA)^{-1}A^TX^T[/itex]
A is a 3-by-2 matrix such that it has full column rank i.e. the two column vectors are independent of one another. Now, A is not restricted to "almost orthogonal" matrix P of your method.
Now your projections are stored as column vectors in a 3-by-n matrix Y, not row vectors like the original coordinates stored in X. Furthermore, the projections are coordinates with respect to the standard basis of the 3D space.
Hey Onako.
Projections have the property that P^2 = P. This means that if you apply a projection more than once to a piece of data that is already projected, the result will not change. This is a fundamental property of all projections.
Thanks for the answers.
I believe that my initial interpretation was correct, but I need to add "projection surface". With it, the matrix
multiplication from above could mean change of the viewpoint, but also the projection surface.
If its a standard orthogonal project, your surface is just a simple oriented plane in the appropriate number of dimensions which can be represented using standard means [like n . (r - r0) = 0]
  • · Replies 33 ·
